Injector Removal Question
Old Apr 7, 2004 | 06:07 PM
oemDC2's Avatar
Default Injector Removal Question
I pull out my injectors and gasoline gushed out from the injectors and fuel rail, is this normal?
Old Apr 7, 2004 | 06:10 PM
isuhonda83's Avatar
yes it is... even when the engine is not running there will be fuel sitting in the rail
Old Apr 7, 2004 | 06:13 PM
alpha's Avatar
Default Re: Injector Removal Question (oemDC2)
Probably forgot to relieve the fuel pressure.
Old Apr 7, 2004 | 06:14 PM
oemDC2's Avatar
Default Re: Injector Removal Question (0x64)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">Probably forgot to relieve the fuel pressure.</TD></TR></TABLE>
Even if i forgot to relieve the fuel pressure, i should be fine right?
Old Apr 7, 2004 | 06:15 PM
5STAR3's Avatar
just make sure you turn the key but dont start the car and hold it there for 10 seconds. do this 3-4 times.
Old Apr 7, 2004 | 06:16 PM
alpha's Avatar
Yes. You will be fine.
Old Apr 7, 2004 | 06:17 PM
oemDC2's Avatar
Default Re: Injector Removal Question (envision2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg &raquo;</TD></TR><TR><TD CLASS="quote">just make sure you turn the key but dont start the car and hold it there for 10 seconds. do this 3-4 times.</TD></TR></TABLE>
What will this do?
Old Apr 7, 2004 | 06:18 PM
5STAR3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oemDC2 &raquo;</TD></TR><TR><TD CLASS="quote">
What will this do?</TD></TR></TABLE>
charge the fuel lines.
Old Apr 7, 2004 | 06:19 PM
yellow blur's Avatar
This will prime the fuel pump and it will build up pressure in your lines to better help start up.
Old Apr 7, 2004 | 06:22 PM
oemDC2's Avatar
Default Re: Injector Removal Question (yellow blur)
Cool.. Thanks for the help
Old Apr 7, 2004 | 06:33 PM
dunkd's Avatar
yah dont worry about it
Old Apr 7, 2004 | 08:23 PM
MrCivic98's Avatar
Default Re: (dunkd)
How do you relieve the pressure in the lines?
silverskateEF9
Jul 15, 2007 02:20 AM
ballerchild
10
Mar 17, 2007 11:16 PM
RTW DC2R
Aug 29, 2005 05:57 PM
95excoupe
Dec 19, 2004 09:38 PM
