Bone yard boost on d16z6.
Old Apr 5, 2004 | 09:55 AM
APEXI Si's Avatar
Default Bone yard boost on d16z6.
Ladies and gents I am back. You are looking at my newly boosted EG. I got that car about three months ago from a friend. At that time the car was white and had some ricy Z3 fenders and was dumped on some APC coils with stock struts. One up side is that it is a 1993 CX and has been swapped with a 95 D16Z6 ( 2020 Lbs with only the spare gone from the interior). The car was also received with a JDM **** carbon fiber hood. It currently has 14 inch Del Sol wheel painted black with Falken 512?s. The APC suspension was swapped out and replaced with Bilsteins and Eibach springs (Thank you Sterling for the great deal on those). The fenders and bumper was replaced with stock and the car was dropped of to be painted (steel gray metallic).Pics of my car right after I got it painted click here http://www.ef-honda.com/main/viewtopic.php?t=1772. Once the exterior was done the turbo project was commenced.
The turbo project was all custom work. I used a ported HF manifold with a BMC adapter plate. I chose to go with a T25 because they are a great turbo to run for street fun. It spools up at around 2,000-2,500 rpm and pulls to about 6,000-7,000 rpm. I took the sock wastegate and threaded it for a bit more of adjustability. I also took advantage of the stock T25 o2 housing as well. The down pipe was made with 2.5? piping to match my exhaust. The cat was also removed during the down pipe fabrication. The Steel braided oil feed line was bought from Fast-Turbo.com (get prices for anybody that is looking). I used an oil drain off of a Saab T3 turbo. The coolant lines are all OEM Mitsu. For cooling my charge air I went with a DSM side mount intercooler. The reason I went with that is because I am not a flash car kind of guy so I thought the SMIC would be pretty unnoticeable? and it is. I ran 2? charge piping fro everything. If you look closely you can see that I am running a pretty inconspicuous BOV right in front of my pass. shock tower (bolted to the engine bay). I was worried that the side-mounted intercooler would not be enough cooling for me but I was wrong. Every time I have driven it so far the charge piping is cool to the touch, even after a 3-hour drive back from Chicago. For fuel I am running DSM 450?s with stock OBD1 clips. Yes, OBD1 clips fit ( just need to modified a bit). I used the solderless installà found here https://honda-tech.com/zerothread?id=736737. I also am running a EM1 fuel pump. For fuel management I am running Uberdata. The car is great and runs perfect. I run 7lbs in the low gears and 7-9lbs in the upper gears. I hope it hold up well and dose not leave me stranded on the side of the road. Sorry no dyno #'s of times yet.
Big thanks goes out to: Paul, Adam, Kev, Luke, Hugo, Jeremy (charge pipe master), Rob, and the rest of 075 for the support.
Old Apr 5, 2004 | 10:59 AM
nigel's Avatar
must have more pics.
lookin good tho. its ghetto but its clean ghetto.
Old Apr 5, 2004 | 12:07 PM
1bar's Avatar
Default Re: (nigel)
looks good should post a pic of the whole engine bay.
Old Apr 5, 2004 | 01:29 PM
thenick's Avatar
Default Re: (1bar)
i love it.
sorry for the nub question but what's the difference between that T25 and a 14b?
i love your setup, but the only problem i see is the length of the intercooler piping. a front mount would do you nice, if you painted it black. it would some of that unnecessary ic piping down some, and leave room for an upgraded turbo down the line.
job though
Old Apr 5, 2004 | 06:01 PM
APEXI Si's Avatar
Default Re: (ixiblindixi)
i love my side mount. cools perfect and it is very unnoticeable. and not to mention if i painted it black it would cut down the cooling effect.
I chose every thing in my kit for a reason. i wanted to go pretty stock looking.
Old Apr 5, 2004 | 06:42 PM
phcnfast's Avatar
14b is little bigger so you get more top end. The t25 runs out around 5-5500 rpm
I agree with stock looks good.
Old Apr 5, 2004 | 06:46 PM
hulkhb's Avatar
Default Re: (phcnfast)
ghetto-FABULOUS
Old Apr 5, 2004 | 08:14 PM
PHiZ's Avatar
Default Re: (hulkhb)
I'm looking at the inlets on the BOV, and now I wanna see the completed charge piping.
Nice project.
Edit, must be nice to have a brake for making heatshields, that looks so nice. See junkyard stuff can look top notch, It always amazes me how a coat of spraypaint can make just about anything look professional.
-PHiZ
Modified by PHiZ at 1:27 AM 4/6/2004
Old Apr 5, 2004 | 08:32 PM
Bailhatch's Avatar
Default Re: (PHiZ)
yes, show the charge piping please
Old Apr 5, 2004 | 10:09 PM
*Boostwerks*'s Avatar
Werdz.
Reminds me of my old T-25 setup 4 years ago...haha.
Good work!
Old Apr 5, 2004 | 10:37 PM
lazerus's Avatar
Default Re: (Bryson)
nice but next time..
use...
para..
graphs
Old Apr 23, 2004 | 12:39 PM
drewbie*'s Avatar
Default Re: (lazerus)
give him a break... he's from michigan... btw thats a joke i have family in mi
Old Apr 23, 2004 | 04:08 PM
T-RO's Avatar
Glad to see someone was able to use my solderless install writeup.
Old Apr 26, 2004 | 11:21 AM
PHiZ's Avatar
Default Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO &raquo;</TD></TR><TR><TD CLASS="quote">Glad to see someone was able to use my solderless install writeup. </TD></TR></TABLE>
I've reccomended several ppl to you solderless resistor box intstall, as a matter of fact it's time to bump that thread, from the dead.
-PHiZ
Ressurect that ****, like easter.
Old Apr 26, 2004 | 11:47 AM
Default Re: (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">
-PHiZ
Lol
Old Apr 27, 2004 | 02:31 PM
drewbie*'s Avatar
how much did the turbo setup set you back? would be a cool little ride ..t25 and a little 30 or 50 shot
Old Apr 27, 2004 | 02:49 PM
onePOINTsix's Avatar
Default Re: (Drew95eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew95eg &raquo;</TD></TR><TR><TD CLASS="quote">give him a break... he's from michigan... btw thats a joke i have family in mi </TD></TR></TABLE>hey i'm from MI too, but i think it's a Grand Rapids thing Nice setup, and nice repping the 075
Old May 11, 2004 | 02:17 AM
2SLO2RCE's Avatar
Default Re: (Sideout)
sweet set up, did you build your bottom end and how much boost are you looking to push?
Old May 11, 2004 | 02:20 AM
5STAR3's Avatar
Default Re: (2SLO2RCE)
so confused.......
ddnt i see this same post like a year ago?
Old May 11, 2004 | 09:36 AM
jaydmcrx's Avatar
Default Re: (envision2teg)
I rode in this car a few weeks ago, and it pulled great. Very smooth. Great junkyard kit guys, very well done
philly10psi
Aug 24, 2011 09:01 AM
kanaboy
14
Dec 18, 2009 12:08 PM
gooberguy31
Feb 28, 2008 08:38 AM
VAsol
Nov 23, 2003 02:58 AM
