strange coolant issue
Old Apr 6, 2004 | 08:50 PM
BoostedITR41's Avatar
Default strange coolant issue
ok guys I have no idea what this could be or mean. the coolant in the over flow is slightly low and darker in color. at first I thought head gasket but I am not sure because:
1. the car doesn't smoke at all except at start up on cold mornings(I would guess condensation) and black smoke very top end(rich)
2. the car doesn't over heat at all. infact coasting down large hills in cooler spring like weather(under 60 degrees) the temp gauge actually drops a bit then when idling it comes back to tempeture
3. doesn't seem to be seeping out from the HG area
4. oil is not milky at all
I have no idea what it could be. could it just be that I need to flush the coolant system? any ideas?
Old Apr 6, 2004 | 09:01 PM
lazerus's Avatar
Default Re: strange coolant issue (BoostedITR41)
yeah.. you probably have dirty coolant..
Old Apr 6, 2004 | 09:04 PM
Default Re: strange coolant issue (lazerus)
well I figured that is why it was dark but would it get lower cause it is dirty? does it like burn off some of the water in the 50/50 mix and that be a reason...this has me stumped cause if it was the HG it would have one of the above symptoms right? I mean the coolant doesn't bubble or anything I don't think air is gettin in
Old Apr 6, 2004 | 09:34 PM
ATS*Mark's Avatar
OG triple OG
thermal expansion and contraction is why its lower flush your cooling system
20civic01
Honda Civic (2001 - 2005)
17
Feb 23, 2014 06:40 PM
tianporn
Feb 26, 2011 10:58 PM
JDM_SOHC
21
Mar 18, 2010 10:14 PM
EvenStar
Feb 5, 2007 11:23 AM
94gsr18kid
Dec 29, 2004 08:12 AM
