Can I get away running injectors like this? Pic inside
I bought a p28 chipped tuned for 550's with a vortech supercharger. My question is can I run the(stock) injectors like this, with the chip tuned to 550's till I get to a tuner? Should I just get bigger injectors before I start my motor,get a baseline chip, and break it in that way? Hondata is my fuel management
Modified by redturbocivic at 3:37 AM 4/6/2004
Re: Can I get away running injectors like this? Pic inside (redturbocivic)
I wouldn't, you don't want a leak and have your motor catch on fire or run lean because of a leak, then detonate and possibly catch on fire.
Re: Can I get away running injectors like this? Pic inside (speedworks)
Thanks that problem is solved. Number 2 problem:: I bought a hondata p28 ecu tuned for 550cc injectors with a vortech supercharger. Can I use stock injectors to break in my motor with that ecu tuned for 550cc injectors. Should I get that chip out of there and get a base map hondata chip in there for some bigger injectors?
ive done it before also when one broke off.. just make sure the orings are in good shape to seal it..
jtkc
10-16-2013 05:48 AM
96redgsr
07-21-2004 09:46 PM
