HONDATA EXPERTS NEED!*
Old Nov 14, 2004 | 06:46 PM
b00sted_GS-R's Avatar
Default HONDATA EXPERTS NEEDED!*
I got my car tuned couple weeks agowith the Hondata s100 with boost, P28 ecu, now its throwing the code 16(fuel injectors) and 21(vtec solenoid valve),.I changed out the solenoid and still throwing the code.From my understanding If my injectors were faulty my car would run like ****..and everytime i start the car, the code is erased. my car drives normal with no probs until I hit around 5-5500 rpm. Soon after the CEL is on it wont let me go past 3500rpm.
I dont know what to do, please help me.
Modified by b00sted_GS-R at 4:27 AM 11/15/2004
Old Nov 14, 2004 | 07:16 PM
atsdelsol's Avatar
Default Re: HONDATA EXPERTS NEED!* (b00sted_GS-R)
open the ecu there might be a loose connection. Have the soiders checked on the socket. Your car is in limp mode. If all esle fails take it to guy that tuned it. Also you might have the rev limit set at 3500?
Old Nov 14, 2004 | 07:28 PM
Blown90hatcH's Avatar
First I guess have you checked the fuel system, etc to confirm that it really does/does not have a problem? If so, you can disable the injector check in Hondata.
Default Re: HONDATA EXPERTS NEED!* (atsdelsol)
ran fine for like 2-3 weeks, with no probs.
Old Nov 15, 2004 | 10:09 AM
bump* need some more advice...my fuel system is fine.
Old Nov 15, 2004 | 01:00 PM
Spunkster's Avatar
what is the COMPLETE ecu code?
Old Nov 16, 2004 | 07:05 PM
Default Re: HONDATA EXPERTS NEED!* (Spunkster)
codes reads
37820-P28-A02
760-763526
Old Nov 17, 2004 | 05:14 AM
Griffin@Camtech's Avatar
Default Re: HONDATA EXPERTS NEED!* (Blown90hatcH)
disable the code in the hondata system. For some reason some ecu's throw that code for no reason. never been able to figure it out myself
Old Nov 17, 2004 | 08:38 PM
Default Re: HONDATA EXPERTS NEED!* (Stickdeath)
could it be a bad chip?
Old Nov 19, 2004 | 09:17 AM
bump
P12 EG6
Dec 5, 2007 08:28 AM
tunerkid07
Aug 28, 2007 02:43 PM
THEUSED
Apr 1, 2006 04:08 PM
FOrSfEd
Nov 16, 2003 03:09 PM
autoEXturbo
Apr 25, 2003 09:41 AM
