Car just died on the street
i was driving to the gas station. this is my first fillup since i put in my turbo. the car is already tuned. well newayz i filled up my tank, started the car and pulled out into the street. after one min when i get to a redlight the car just dies for no reason, shuts off completly. well some guy helped me pull into a parking lot and tried to crank it and it sounded like it wanted to go but didnt. tried it one more time and applied gas and it turned on. anyone know what could be the prob.
Fuel setup:
Walboro 255lph
rc 550cc.
Fuel setup:
Walboro 255lph
rc 550cc.
Re: Car just died on the street (Boosted Chemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist »</TD></TR><TR><TD CLASS="quote">do you have fuel pressure? do u have spark? do u have compression?
what is your EMS?</TD></TR></TABLE>
i dont have a fuel pressure gauge. everything was running fine till i got gas(LOL). i have hondata s100(st00pid tuned).
Re: Car just died on the street (eg6T)
This happened to me and as I was tunning I realized that my 3 bar map sensor was reading full 28 PSI when the car was off. I just went ahead and jiggled wires and then it started right up. If you have a 3 bar this might be it. Holding the throttle full open doesn't do anything on a full injected car anyway since they run off vaccum presence.
Re: (Sinner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sinner »</TD></TR><TR><TD CLASS="quote">is your car tuned? check for fouled plugs</TD></TR></TABLE> my car is tuned i stated above. i havent checked the plugs but i mean the car runs now. but i was just wondering why that happened it is really strange
Re: (TurboSmart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSmart »</TD></TR><TR><TD CLASS="quote">Ignitor gone bad?</TD></TR></TABLE> if it gone bad i wouldnt be able to start the car? what about fuel guys? the only way the car started was that i had to give it gas
Re: (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">adjust the cranking fuel </TD></TR></TABLE> this is the first time this ever happened. how do i do that. is st00pid suppose to do that?
Re: (eg6T)
im gonna vote fuel pressure. this happened to me recently, are you running the stock fpr? seeing as you didnt list it up top im assuming no. this may be the problem. im putting in an aeromotive fpr this coming week.
Re: (f22b2tdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f22b2tdave »</TD></TR><TR><TD CLASS="quote">im gonna vote fuel pressure. this happened to me recently, are you running the stock fpr? seeing as you didnt list it up top im assuming no. this may be the problem. im putting in an aeromotive fpr this coming week.</TD></TR></TABLE>
how did you figure it was your fuel pressure? im running the stock fpr and i seem to be fine
Re: (1zexxedcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1zexxedcivic »</TD></TR><TR><TD CLASS="quote">did u install that fuel pump correctly, cause the car wont run right without the filter.</TD></TR></TABLE>
i installed the fuel pump exactly from c-speedracing.com pretty much plug and play. the fuel filter i havent changed. the car does run now like b4 but i just find it strange.
Re: (XxRoCkMaNxNEOxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XxRoCkMaNxNEOxX »</TD></TR><TR><TD CLASS="quote">
i installed the fuel pump exactly from c-speedracing.com pretty much plug and play. the fuel filter i havent changed. the car does run now like b4 but i just find it strange. </TD></TR></TABLE>
hmm strange, cause when installed my fuel pump wrong my car did the same thing when it gets low on gas. It sounds like the ignition but when i brought it to the shop the car wasnt gettting any fuel so it was a fuel pump failure.. i later found out that the filter i dropped in with my walbro intank was installed correctly and it shitted on me.
Re: Car just died on the street (XxRoCkMaNxNEOxX)
It happened to me before, as many people say it's fuel pressure, however the cause of your problem it's not your fuel pump or regulator.
Even it's hard to believe, your main relay it's going bad and sometimes it fails to work for a while specially when you shutoff the car for a few minutes and then you try to start it again. I would get me a spare relay and have it in the car or replace it 'cause it won't get any better.
Re: Car just died on the street (hybrixt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrixt »</TD></TR><TR><TD CLASS="quote">It happened to me before, as many people say it's fuel pressure, however the cause of your problem it's not your fuel pump or regulator.
Even it's hard to believe, your main relay it's going bad and sometimes it fails to work for a while specially when you shutoff the car for a few minutes and then you try to start it again. I would get me a spare relay and have it in the car or replace it 'cause it won't get any better.</TD></TR></TABLE>
main relay? where is that what do i have to buy?
Vagitarian
03-17-2014 01:40 PM
