oil spraying out during 18+ psi boost
During high boost, small amounts of motor oil is sparying out of this "nozzle" (excuse my lack of knowledge) What is going on and should I be concerned?
Re: oil spraying out during 18+ psi boost (ekhatch18tR)
thats part of your positive crank ventilation system. get a catch can and youll be good.
by the way whats your setup? 18+psi is kinda high for someone who doesnt know about the pcv system....Im not bashing on you, just looking out for ya. I know some shops will lead you in the wrong direction to make a buck or two. are you running some type of FMU other than a vafc?
Re: oil spraying out during 18+ psi boost (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure »</TD></TR><TR><TD CLASS="quote">How does blow by result in pressure getting into the head?</TD></TR></TABLE>
How do you think oil drains from the head back into the pan?
Re: oil spraying out during 18+ psi boost (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx »</TD></TR><TR><TD CLASS="quote">
How do you think oil drains from the head back into the pan? </TD></TR></TABLE>
Good point, thanks for clearing that up.
Re: oil spraying out during 18+ psi boost (m R g S r)
You need th endyn positive crankcase ventilation system.Not only will it save you from all the mess it will increase the live and power of your engine.
Re: (D15B7turbo)
A breather will just get all oily. Get the Endyn catch can setup.
And don't jump the gun and think it is due to bad rings or cracked ring lands. This is common on high boost/hp setups.
Re: (BodyKits NW)
Looks ok...went and boosted HARD for 15 min on the highway at 18 psi with sock tied to strut bar, than checked, no oil...just hot gases burning the sock. Than parked and revved some more to make sure:
Modified by ekhatch18tR at 1:32 PM 12/17/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">I think the oil is due to the unplugged MAP sensor.</TD></TR></TABLE>
lol
lol
Re: (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">Well you were in neutral there, not even boosting it. So I guess your saying it happens at 0 load or vaccuum?</TD></TR></TABLE>
"went and boosted HARD for 15 min on the highway...Than parked and revved some more to make sure"
reading is fundamental
