Diy catch can.
Old Nov 17, 2004 | 07:07 AM
HamiltonRex's Avatar
Default Diy catch can.
I used my stock Charcoal canister. Cut it open and emptied the stuff. Welded it back up. And used the bottom as a drain i put a valve on there.
Then the top is where i connected my PCV and Intake hose. Then i plugged up the Holes where the PCV and Valve cover breather went.
In about a month its almost half full of black sludge (i put a little hose in the side so i could see how full it is, l ike the G-reddy one) So its working well.
I just vented the tank though a small hose (no oil comes out)
Just wondering if anyone else has done something similar, or if you all buy the bling bling tig welded stainless ones?
Old Nov 17, 2004 | 07:19 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Diy catch can. (HamiltonRex)
That is a good way to make dew with what you have but it sounds like a pain in the *** to drill and install all those fittings when you can get a generic can for like 25$ and not have to do all that pin in the *** work
Old Nov 17, 2004 | 07:20 AM
underpressure02's Avatar
Default Re: Diy catch can. (si2die4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si2die4 &raquo;</TD></TR><TR><TD CLASS="quote">That is a good way to make dew with what you have but it sounds like a pain in the *** to drill and install all those fittings when you can get a generic can for like 25$ and not have to do all that pin in the *** work </TD></TR></TABLE>
You may want to post where you can get a generic can for $25 bucks. I know a few people on here that were looking for cheap catch can's. The ony guy wanted to make one out of a soda can.
Old Nov 17, 2004 | 07:30 AM
beepy's Avatar
Default Re: Diy catch can. (underpressure02)
Cheapest catch can: Air tool air/oil seperator. $13 at Home Depot. They are designed to flow well and catch oil particles as small as 3 microns. Can't beat that.
Old Nov 17, 2004 | 07:35 AM
i my honda
Global Mod
Default Re: Diy catch can. (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Cheapest catch can: Air tool air/oil seperator. $13 at Home Depot. They are designed to flow well and catch oil particles as small as 3 microns. Can't beat that.</TD></TR></TABLE>
Thats what I was talking about. Also there are some crome crap ones on Ebay for right around that price 2.
Here is one http://cgi.ebay.com/ebaymotors...=6763
Old Nov 17, 2004 | 08:09 AM
StolenTeg's Avatar
Here is one http://cgi.ebay.com/ebaymotors...=6763</TD></TR></TABLE>
I got that catch can, quality is good. Havent had the chance to hook it up yet tho. also need to fill the can with something.
Old Nov 17, 2004 | 12:10 PM
RyanEJ8's Avatar
Or to make things even easier you could just pull out the PCV valve and run a hose out the bottom of the car. It's not the most environmentally friendly setup, but it's not like the DIY can is emissions legal either.
Old Nov 17, 2004 | 12:18 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: Diy catch can. (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
Or to make things even easier you could just pull out the PCV valve and run a hose out the bottom of the car. It's not the most environmentally friendly setup, but it's not like the DIY can is emissions legal either.</TD></TR></TABLE>
I would do that but I live in CALI
Old Nov 17, 2004 | 12:43 PM
Default Re: Diy catch can. (NightRider-gsR)
I think the hose down the PCV on the ground is the best way.
Afterall when our catch cans get full what do we do with the junk thats in them anyways??
Thanks for all the idea's
Old Nov 17, 2004 | 12:49 PM
Syner-G-Racing LLC's Avatar
or you can do like my dad and I use to do on his 424 SS. take a beer can and some steel wool, or a coffee can.
Old Nov 17, 2004 | 01:10 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR &raquo;</TD></TR><TR><TD CLASS="quote">
I would do that but I live in CALI </TD></TR></TABLE>
Yeah you can't do much of anything in Cali.
Old Nov 17, 2004 | 01:16 PM
StolenTeg's Avatar
where the pvc located in a b18b1 newer model...
Old Nov 17, 2004 | 03:05 PM
B18C1CYA's Avatar
here is one i made and it works great , the welds arent the best it was my first time welding aluminum
here it is installed on my car with the filter, o btw this was my second one
Old Nov 17, 2004 | 03:36 PM
i my honda
Global Mod
Default Re: Diy catch can. (B18C1CYA)
That looks great man Baffled too
I like that craftsman compressor too
How far does the center section go down (I am guessing all the way) and how many holes are in it?
Is it welded on the bottom? (where the center section meets)
How much to make me one?
Old Nov 17, 2004 | 03:46 PM
B18C1CYA's Avatar
that tank is my portable air tank , but i do have a craftsman air compressor ,lol and the baffle has probly 30-40 holes about 1/8'' size, and is about 1 inch from the bottom of the can , and yes the bottom of the baffle is welded up.
Old Nov 17, 2004 | 04:34 PM
I tried Tig welding today for my first time on mild steel. I want to get good before i build my Turbo manifold..
Its soooo hard. First time i didtn wear gloves, and the filler rod got short, then super hot real fast and it burnt a line across my fingers
Im starting to get the hang, ours has the foot pedal too, so its nice. My welds arent the best.. But i only welded about 6" on a piece of flatbar doing lap joints. Took me like 20min between new rods, cleaning the tungsten and burning myself.
Old Nov 17, 2004 | 04:46 PM
Blackack26's Avatar
I used a piece of ABS piping for my catchcan and stuffed it with one of those shower scrunchy things..... works awesome.
Old Nov 17, 2004 | 05:20 PM
Default Re: Diy catch can. (Blackack26)
Lots of good info here!
I think im going to do something with mild steel, and just paint the outside. My plastic one is horrifically ghetto.
Old Nov 17, 2004 | 07:09 PM
adictionbass's Avatar
so if one were to make one from scratch, how would they do it? How many openings/valves, where should they be, what about vacuum?, where should the filter element go, where should you drain?
Old Nov 17, 2004 | 07:18 PM
In-N-Out Burger
Yeah you can't do much of anything in Cali. </TD></TR></TABLE>
True, I still run my cutout open most of the time
Old Nov 18, 2004 | 03:42 AM
Default Re: Diy catch can. (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">so if one were to make one from scratch, how would they do it? How many openings/valves, where should they be, what about vacuum?, where should the filter element go, where should you drain?</TD></TR></TABLE>
Just a small container, with eaither a bolt on or screw on lid. (some way to get into it)
Have a tap on the bottom or a plug or something. And put to 90deg elbows in the side with a piece of clear hose so you can see the level.
And just on the top, the fitting for Valve cover breather, and PCV and just run hoses into the top. It dosent need to be inline with anything. Just plug up the holes left from where the PCV and VCB went.
Old Nov 18, 2004 | 07:25 AM
so could you put another fiting on the bottom and drain it back to the oil pan? Like a greddy uint?
Old Nov 18, 2004 | 02:18 PM
I dont think youd want that oil to go back in the pan. Just collect it and get rid of it with oil from your oilchanges.
I started building my own catchcan in school today. I rolled some sheetmetal, and am going to have a top and bottom sealed, and like a little rectangle thing protruding from the top with fittings so there at 90deg. Then a plug at the bottom to drain it.
No baffles or internal filtering since it wont be vented back to the IM.
JavierD16
Jul 5, 2018 05:53 AM
Mikes2000civicsi
Oct 26, 2007 05:28 PM
madcrossover
Sep 16, 2004 11:35 AM
tankz0r
Aug 8, 2003 09:11 PM
InfamousRS
Jun 23, 2003 01:20 PM
