Greddy Turbo timer problem..
Old Nov 13, 2004 | 04:31 PM
DruWO's Avatar
Default Greddy Turbo timer problem..
i hooked up the wires exactly like this..
hooked up the brake line, but i didn't hook up the wite to the vss *i was told i didn't have to.*
when i shut off the ignition the cars just shuts off along with the turbo timer..
help me please...haha could it be that i have the factory alarm... or could it be that i didn't hook up the vss wire??
Old Nov 13, 2004 | 04:34 PM
11psiTurboSI's Avatar
Default Re: Greddy Turbo timer problem.. (DruWO)
I didn't use the the vss nor the e-bake wiring and it worked for me
Old Nov 13, 2004 | 09:04 PM
Syner-G-Racing LLC's Avatar
did you set the min. time to 000 or is there a time set? does it even power up.
Old Nov 13, 2004 | 10:05 PM
DruWO's Avatar
Default Re: Greddy Turbo timer problem.. (Syner-G-Racing)
it powers up... and i set the time to 30 seconds.. but then it just turns off when i turn the car off, does this happened because of the stock alarm?
Old Nov 13, 2004 | 10:18 PM
PrettyLude's Avatar
check ur wiring again
Old Nov 13, 2004 | 10:42 PM
Stylinhonda's Avatar
Id check the wires and what mode you have the time set on. Took me forever to figure it out.
Not to hijack, but what about the purple and brown wire. My spedo option does not work, so im guessing its for that or something. How do you hook that up and is it worth going back in and hooking up.
Old Nov 14, 2004 | 01:34 AM
Default Re: Greddy Turbo timer problem.. (Stylinhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stylinhonda &raquo;</TD></TR><TR><TD CLASS="quote">Id check the wires and what mode you have the time set on. Took me forever to figure it out.
https://honda-tech.com/zerothread?id=1055163
Old Nov 14, 2004 | 10:03 AM
DruWO's Avatar
everything is wires up right... just seems to not want to work with the factory alarm... and i'm too lazy to try that relay trick... so i'm selling the TT now...LoL thanks for all the help!
Old Nov 14, 2004 | 10:17 AM
Teglove2's Avatar
I have the purple wire(vss) hooked up also and it doesn't work for me either.
Old Nov 14, 2004 | 10:58 AM
shadow103rd's Avatar
Default Re: (Teglove2)
I went by the exact same picture and I havent had a problem with mine!!!
Jon
Old Nov 14, 2004 | 06:25 PM
95hatch's Avatar
Default Re: (shadow103rd)
check your connection at the ebrake. I used a wire tap on mine and at first it wasnt making a connection. and make you sure you have the ebrake pulled up when you turn your car off of course. The VSS wire is just for time attack and safety features.
Old Nov 14, 2004 | 06:35 PM
PrettyLude's Avatar
the greddy unit doesn't need the e brake to work like the hks one
Old Nov 14, 2004 | 07:35 PM
eg6T's Avatar
Default Re: (PrettyLude)
try switchin over that switch on the back of the unit..mine was all wired up correctly and i switched that switch on the back over and messed with that and it started working perfectly...i still have no clue how i really did it,but it works
Old Nov 22, 2004 | 10:50 AM
tegon-gsr's Avatar
Default Re: (eg6T)
I wire mine up just like the picture had it and mine works fine the only problem i have is with my alarm now i cant lock the doors if the turbo timer is on i have a alpine alarm is there something else i need to do?
Old Nov 22, 2004 | 07:47 PM
PrettyLude's Avatar
Old Nov 22, 2004 | 08:23 PM
XSIintegra's Avatar
leave your ebrake down and try it. I metered out my connection on my '92 DA and I was getting the opposite voltage that the TT requires, so I never bothered hooking it up. Doesn't matter now because it got stolen =P
incognitoracerr
Apr 6, 2003 09:19 PM
Shaun K
Apr 17, 2002 07:53 PM
ken
Oct 29, 2001 04:28 PM
FBP Si 2000
Sep 28, 2001 05:54 PM
Lei Siew Long
Jun 30, 2001 12:17 AM
