controlling the boost
Old Nov 14, 2004 | 12:52 AM
MostlyR's Avatar
Default controlling the boost
currently, i am using a greddy boost controller running at 0.45 bar which is equivalent to 7psi. Is there anything I can buy or do to make the turbo run at a lower psi, preferably 4 psi? Or is there a way i can just turn off the turbo completely while leaving the turbo kit and intercooler under the hood?
Old Nov 14, 2004 | 01:09 AM
sir boostalot's Avatar
Default Re: controlling the boost (PY Type R)
I think you can do it by hand with an external wastegate that comes with spring adjusmentl.
Old Nov 14, 2004 | 01:32 AM
Frozen E's Avatar
H-T White Ops
the only thing you can get is a lower rated spring. What kind of wastegate are you running? If it's a Tial or any of the big name external ones you can swap out the spring in there. As far as "turning off" the turbo.....not gonna happen.
Old Nov 14, 2004 | 01:48 AM
Syner-G-Racing LLC's Avatar
Default Re: (IslandSi)
you can remove the spring completely and the waste gate will not retain the pressure...meaning you cant boost. or if its internal just lockwire the waste gate linkage open.
2LiterTurboSeR
Aug 25, 2005 11:04 PM
LSEGHATCH
Dec 15, 2004 10:51 PM
5l-eater
Oct 20, 2004 03:26 PM
oMek
Feb 29, 2004 09:09 PM
Mikex25
Aug 30, 2001 01:28 AM
