Precision sc51 ?
Old Nov 14, 2004 | 07:57 AM
1RMDave's Avatar
Default Precision sc51 ?
So i'm trading my head for a brand new sc51. Anyone know the specs on one of these or any information? I didn't see it listed on precisions website and my search on here came up blank.
Its for my b18a.
Old Nov 14, 2004 | 07:18 PM
1RMDave's Avatar
bump
Old Nov 14, 2004 | 08:42 PM
1RMDave's Avatar
bump.
Old Nov 15, 2004 | 12:51 PM
1RMDave's Avatar
ttt
Old Nov 15, 2004 | 12:55 PM
Ben Huynh's Avatar
Default Re: Precision sc51 ? (1RMDave)
It's either an SC50 or SC61. I don't show an SC51.
Old Nov 15, 2004 | 01:44 PM
1RMDave's Avatar
must be an sc50. its .63 on the exhaust.
Old Nov 15, 2004 | 01:54 PM
Sonny's Avatar
Like Ben said, it's either an SC61 or an SC50.
If it's an SC50, it's basically a Garrett Stage 3 turbine wheel and a Garrett T04E 50 trim compressor wheel. The SC50 is a badass turbo. I regret selling mine.
Sonny
Old Nov 15, 2004 | 02:52 PM
liam821's Avatar
25 Year Member
Default Re: (1RMDave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1RMDave &raquo;</TD></TR><TR><TD CLASS="quote">must be an sc50. its .63 on the exhaust.</TD></TR></TABLE>
you can get the sc61 with a .63 exhaust fyi
Old Nov 15, 2004 | 02:57 PM
Ben Huynh's Avatar
Default Re: (liam821)
The SC61 only omes with the .63 AR. They no longer make it with the .48 AR.
Old Nov 15, 2004 | 03:02 PM
1RMDave's Avatar
hmmm wonder if the guy ment sc61. Guess i'll find out when it gets here. i sent my payment today. I'll be happy either way. I just need boost and I hear precision is good.
Old Nov 15, 2004 | 03:03 PM
1RMDave's Avatar
Just found out it is indeed an sc50 with a .63
Hopefully i'll be happy. whats the spool gonna be like on my stock b18a?
Old Nov 15, 2004 | 03:09 PM
Sonny's Avatar
It's gonna hit pretty late on a B18A. I'm guessing 5000 rpm. You might wanna switch housings. I know Precision will do it for you if you call them up and ask. I had a .48 a/r SC50 and they told me that switching to a .63 a/r at later date was no problem.
Sonny
Old Nov 15, 2004 | 03:23 PM
1RMDave's Avatar
really that high? I really thought it would be lower. Don't people use these on d-series?
Old Nov 15, 2004 | 03:24 PM
1RMDave's Avatar
I think 5000 might be alittle high. I was thinking more along the lines of 4000
Old Nov 15, 2004 | 04:04 PM
brickonwheels's Avatar
I've always been told people were hitting full boost around 3500-4000 rpms on stock b18a/b
Old Nov 15, 2004 | 04:07 PM
alpha's Avatar
Default Re: (Sonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny &raquo;</TD></TR><TR><TD CLASS="quote">
Sonny
5,000RPM isnt right. He should see Full Boost around 4,000RPM - 4500RPM depending upon his boost level, exhaust setup, etc. I have seen SC61S turbochargers making 16lbs @ 4700RPM - 4800RPM on stock head B18b engines.
Old Nov 15, 2004 | 05:13 PM
eg:R's Avatar
so with a bigger exhast side, it will spool faster???
Old Nov 15, 2004 | 06:40 PM
smaller=faster spool
Old Nov 15, 2004 | 07:45 PM
1RMDave's Avatar
3500 would be nice
Old Nov 16, 2004 | 06:37 PM
So anyone actually know? i'll be able to tell you as soon as i get my car running.
Old Nov 16, 2004 | 06:52 PM
Sonny's Avatar
You'll be the first to tell us. My guess is still 5000 rpm assuming it has a stage 3 turbine wheel. The stage 2 wheel was an option when I bought mine.
It might actually make boost sooner, but 5000 rpm is my guess as far as when it will be useable.
Sonny
Old Nov 16, 2004 | 09:16 PM
shermanyang's Avatar
Default Re: (Sonny)
63 ar stage 3 on a stock LS would spool right around 3.3-3.5k and reach full around 4.6-4.8k. it doesn't take long once the turbo gets going...but there is some lag and you won't notice the power till a bit after 5k.
Old Nov 16, 2004 | 09:25 PM
Blackack26's Avatar
Default Re: (shermanyang)
I get full boost around 4200 - 4500 rpm
Stock b18a
SC50 .63 hot
Old Nov 16, 2004 | 11:55 PM
Sonny's Avatar
Default Re: (Blackack26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 &raquo;</TD></TR><TR><TD CLASS="quote">I get full boost around 4200 - 4500 rpm
Stock b18a
SC50 .63 hot</TD></TR></TABLE>
Did you get the stage 2 turbine or stage 3?
Good info. B18A might have a future in my CRX.
Sonny
Old Nov 18, 2004 | 03:03 PM
So what might i be able to expect with a .48 hot side?
alperx
Feb 8, 2012 05:34 PM
xenocron
Jan 12, 2009 07:00 AM
SL0WEGG
Jan 4, 2006 01:34 PM
speeds
Jan 16, 2005 05:39 AM
Anubyss
Sep 16, 2004 09:16 AM
