Help diagnose a strange idle *vid included*
This developed a couple days ago, and seems to be getting worse, but maybe that's just me. anyway, I get a very lumpy idle, that continues through light load, but under full load the car hauls *** like it always used to. It also vibrates more then normal during idle. I'm guessing its either distributor, plugs/wires, or maybe something with internals? If that's the case, then I've lasted 2 yrs and 35k with a boosted stock B16 at 9 psi. w00t
here's the vids.
Startup: you can really hear it stutter during cranking
http://webhome.idirect.com/~otipihyr/MVI_0956.AVI
and out by the exhaust. not as noticeable, but if you listen you can still catch it.
http://webhome.idirect.com/~otipihyr/MVI_0953.AVI
here's the vids.
Re: Help diagnose a strange idle *vid included* (Canuk_SiR)
sounds exactly like my prelude when i had bent valves and when my egr stuck open...but you dont have egr..so maybe the valves.
Re: Help diagnose a strange idle *vid included* (LudeSH)
sounds like poo. I would start by replacing the cap, rotor, wires and plugs. if you have some type of fuel/ignition management. make sure the timing is right. if that doesnt fix it. do a compression and a leak down test. if your running a cat...thats the problem ( ist probaly melted) if not check your valve clearence. good luck
stephane613
01-19-2008 06:53 PM
vlc92189
11-14-2007 06:52 AM
