need some help...can I do this??
Old Nov 15, 2004 | 08:31 PM
ViruSi's Avatar
Default need some help...can I do this??
Hey guys I got a full greddy turbo kit for 99-00 civic si b16a2 and was wondering if I could install the injectors(310cc) and bluebox now and drive around for maybe a week or so before I install the rest. Will I encounter any problems or harm the engine? Thanks.
Old Nov 15, 2004 | 09:21 PM
ViruSi's Avatar
Default Re: need some help...can I do this?? (ViruSi)
bump...need to know ASAP
Old Nov 15, 2004 | 10:19 PM
Si Shane's Avatar
Installing the blue box takes about 15 minutes, if you have the diagrams. I have them if you dont, let me know. There is NO reason you should do this. None. You are talking about a 30min job here. Just wait and spend the 30 min when your car is on jackstands. I dont understand why you would even think about this?
Old Nov 15, 2004 | 10:23 PM
SOHC_MShue's Avatar
did those injectors come with the kit? I thought the blue box was made to run stock injectors.
Old Nov 16, 2004 | 07:10 AM
ViruSi's Avatar
Default Re: need some help...can I do this?? (SOHC_MShue)
yeah they came with the kit. I just wanted to get this done so when I install the turbo it will be much quicker. So would it be ok to do? or maybe just installing the injectors for now?
Old Nov 17, 2004 | 09:18 AM
gsrt nick's Avatar
I ran the blue box and injectors with no boost and it worked fine. The reason I did I was having problems with the blue box leaning out under boost so set the wastegate to be fully open at all times. until I got a new fuel system
Tetronious
May 25, 2006 05:28 PM
skierGT
Jun 28, 2003 11:41 AM
boostincoupe
Jun 26, 2003 10:10 PM
bld
Nov 26, 2002 10:12 PM
