any new developments in e-cutouts?
Old Nov 14, 2004 | 11:21 PM
falcongsr's Avatar
What is this crap?
Default any new developments in e-cutouts?
are there any ways to keep stock exhaust and use an e-cutout to bypass everything and dump to a straight pipe?
i know cheesefrog had a good setup but the cutouts couldnt stand the heat of being so close to the turbo and would fail.
is there a reliable solution out there?
Old Nov 14, 2004 | 11:44 PM
B18OnTop's Avatar
Default Re: any new developments in e-cutouts? (falcongsr)
http://www.trials-shack.co.uk/posting.html
https://honda-tech.com/zerothread?id=1013786
Old Nov 14, 2004 | 11:47 PM
falcongsr's Avatar
What is this crap?
Default Re: any new developments in e-cutouts? (B18OnTop)
i did a search and your post did not show up.
thanks
Old Nov 15, 2004 | 12:01 AM
turbogeekDA6's Avatar
check out the VES from http://www.atpturbo.com. its kinda like a wastegate combined with an ecutout.
Old Nov 15, 2004 | 12:07 AM
falcongsr's Avatar
What is this crap?
Default Re: any new developments in e-cutouts? (turbogeekDA6)
yeah. i am afraid the butterfly style cutout is always going to have leaking / rattling / noise problems though. and there is a plastic diaphragm in that gold colored actuator - the heat is going to kill it just like it kills the motors of the e-cutouts.
and that thing has no warranty that i see.
Old Nov 15, 2004 | 01:53 AM
This One's Avatar
I've been using a Setup similiar to Cheesefrog's setup on my Daily driver.
Havent had to many problems with it, Been on the car for a good 5-6 months
I pulled it apart last night actually, and it was starting to loosen up, glad i caught it in time.
It definatly leaks a bunch, Ive tried massive amounts and small amounts of silicone and It doesn't help much. The silicone doesn't like to stick very long.
Other than that no problems really. I rarely close the thing.
I think the people who run around with them closed all the time are the ones who run into problems with them.
Its a quicktime valve
Old Nov 15, 2004 | 04:48 AM
m R g S r's Avatar
Default Re: any new developments in e-cutouts? (This One)
I had the mccord, ran it closed, and opened it alot. It lasted about 2-3 weeks, completly broke. Rattling, stripped gears etc. .
I talked to the person who I bought it from (Mccord) and he told me he would send me the replacement gears. Never received anything.
Now I just run open DP.
Old Nov 15, 2004 | 06:28 AM
turboteg2nv's Avatar
slightly (way) off topic, but where can I get a flange to bolt up a QTP cutout? I bought a 2.5''inch dump but need a flange to weld on.
Old Nov 15, 2004 | 06:31 AM
falcongsr's Avatar
What is this crap?
Default Re: any new developments in e-cutouts? (turboteg2nv)
local muffler shop? they just handed me the one i needed.
Old Nov 15, 2004 | 07:39 AM
falcongsr's Avatar
What is this crap?
so basically e-cutouts are not a viable option for a long term solution.
hrm. i reall wish i was creative enough to come up with something better. somthing using electromagnets to clamp the exhaust shut or open it, it would open quickly and have no motor/gears.
Old Nov 15, 2004 | 07:58 AM
Ckjeepin's Avatar
I use a cutout with a blackoff plate held on by 3 wingnuts...
Im not too lazy to loosen 3 wingnuts when i know i got a run coming up..
Old Nov 16, 2004 | 08:31 AM
falcongsr's Avatar
What is this crap?
Default Re: any new developments in e-cutouts? (Ckjeepin)
i just want my car to open the cutout automatically when i press the pedal to the floor
Old Nov 16, 2004 | 02:39 PM
InTeGrA B18b1's Avatar
maybe you get get the e cutout and instead pressing the button somehow hook it up to your ecu when you a full throttle.
you could put the button under you gas pedal and when you press it in all the way it presses the button
Old Nov 16, 2004 | 02:53 PM
falcongsr's Avatar
What is this crap?
Default Re: any new developments in e-cutouts? (InTeGrA B18b1)
yeah there are ways to do that, i've done it in the past.
the problem is the cutout itself and preventing it from leaking/failing. i have some good ideas on the back burner right now...
Old Nov 16, 2004 | 05:20 PM
BB6-213's Avatar
My DMH 3" just burnt out, hopfully the customer service will be good and replace it.
Old Nov 16, 2004 | 05:21 PM
falcongsr's Avatar
What is this crap?
Default Re: (BB6-213)
butterfly style cutouts will never work! there is a better way
Jamesc183
Aug 4, 2014 03:58 PM
Dave_yd
May 13, 2008 01:32 PM
FrostyDC4
Jul 25, 2007 06:23 PM
2000EM1
Dec 26, 2005 07:59 PM
O16581724 5 2 5
Oct 11, 2005 08:01 PM
