hooking up both wastegate ports using a boost controller?
Old Nov 18, 2004 | 01:38 AM
importboi22's Avatar
Default hooking up both wastegate ports using a boost controller?
i have the avc-r and im trying to figure out the correct way to hook it up (dual). but the engrish on the apexi directions suck. could someone perhaps maybe make a photo on paint for me so i know the correct way? thanks
Old Nov 18, 2004 | 04:29 AM
RacerXI's Avatar
Default Re: hooking up both wastegate ports using a boost controller? (importboi22)
On my car I have...
Top port "COM"
Side port "NC"
open to atmosphere "NO"
Also, you can tee the "NC" port into a vacuum source like from a vacuum block.
Check out page 44 of the install manual. I've seen it posted differently though in the archives. HTH.
Old Nov 18, 2004 | 05:30 AM
pissedoffsol's Avatar
25 Year Member
Default Re: hooking up both wastegate ports using a boost controller? (RacerXI)
Old Nov 18, 2004 | 11:20 AM
Default Re: hooking up both wastegate ports using a boost controller? (pissedoffsol)
does it have to be from the ic piping ? or after the TB is fine?
Old Nov 18, 2004 | 11:57 AM
25 Year Member
no... in fact dont put it there... T it off of a vac source
Old Nov 18, 2004 | 05:23 PM
yes like off the intake manifold or of that nature correct?
Old Nov 19, 2004 | 05:05 AM
25 Year Member
right
ritesh
Jan 2, 2013 06:49 PM
Azndude1983
Feb 15, 2006 05:28 PM
BoOsTiN Dc2
Apr 26, 2004 07:24 AM
Infinity_Racer
Nov 9, 2003 10:41 AM
B20LS-T
Aug 16, 2002 12:40 PM
