can i use stock civic injectors on a turbo step up?
I am going to boost a 00 b16a. I have all the parts, but I keep hearing that I can boost with stock injectors and that I cannot? Just looking for some street smart answers from people who have done this before.
Re: can i use stock civic injectors on a turbo step up? (skitzo7170)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skitzo7170 »</TD></TR><TR><TD CLASS="quote">I am going to boost a 00 b16a. I have all the parts, but I keep hearing that I can boost with stock injectors and that I cannot? Just looking for some street smart answers from people who have done this before.</TD></TR></TABLE>
you can with stock injectors. FMU + missing link + fuel pump
if your building on a buget. the best and fuel set up at a cheap price is a vafc and 450cc dsm injectors with a obd 0 resistor box. I ran that setup on my 98 gsr 10psi for a long time with a stock fuel pump and never had any problems. and if you shop around you could get the whole set up for less than $250.
and your point? lol j/k
if you use stock injectors, you need to use an fmu. fmu's raise pressure, which gives more fuel- to a cerain extent. at some point, the pressure cannot supply enough volume. thats when you blow up. so keep the boost down with an fmu.
not sure about the emanage too much- but you could run the hack with it if it allows a god range of negative numbers to be used.
discrete
14
02-19-2005 04:58 AM
