turbo?
Old Nov 13, 2004 | 02:06 AM
9341civic's Avatar
Default turbo?
is it possible to run a turbo at low boost on this set up?>
b20 block
darton sleeves
je pistons 11.5 c/r
crower rods
b16 head
crower stage 2 cams & valve train
ame ems
Old Nov 13, 2004 | 02:30 AM
Adi Radoncic's Avatar
On Fire!
Default Re: turbo? (9341civic)
yes sir, but you must tune it and keep the boost low!
Or you could run race gas all the time.....?
Old Nov 17, 2004 | 06:17 PM
9341civic's Avatar
more feedback please
Old Nov 17, 2004 | 06:40 PM
adseguy's Avatar
It'll be hard to tune with that 11.5 and on a b20 block can be dangerous since they don't like boost as much as say a b18 or b16 (why?....sleeves?). Very doable though just get a good tuner and you won't need as much boost to get your desired HP sice you are running such a high compression.
Old Nov 17, 2004 | 06:42 PM
ATS*Mark's Avatar
OG triple OG
Default Re: turbo? (adseguy)
on darton sleeves **** ya....you can run like 12-14 lbs and make huge power . do it
Old Nov 17, 2004 | 06:47 PM
m R g S r's Avatar
Go for it, then when your done, you can race meee and my 9:1 b16.
ATS*Mark's Avatar
OG triple OG
Default Re: turbo? (m R g S r)
and my 9.0:1 d series
Old Nov 17, 2004 | 07:14 PM
m R g S r's Avatar
Default Re: turbo? (OnePointSicks)
D series suck
Old Nov 17, 2004 | 07:25 PM
Mag00n's Avatar
Default Re: turbo? (newgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by newgsr &raquo;</TD></TR><TR><TD CLASS="quote">yes sir, but you must tune it and keep the boost low!
Or you could run race gas all the time.....?</TD></TR></TABLE>
WHY???? Hes got sleeves rods and pistons? Boost the **** out of that man. It would be totally pointless to resleeve a b20 and NOT run atLEAST 300whp through it. ATLEAST. Although I'm not sure why you choose the high comp pistons? That does it make it a little more susceptible to problems...
Old Nov 17, 2004 | 07:52 PM
m R g S r's Avatar
Default Re: turbo? (Mag00n)
Because on a decent sized turbo he would probally only need 7psi to make 300whp.
Old Nov 17, 2004 | 07:55 PM
Mag00n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">Because on a decent sized turbo he would probally only need 7psi to make 300whp. </TD></TR></TABLE>
With lower comp pistons that motor could easily and safely make WELL over 300whp.
mink_si
Feb 26, 2007 03:54 AM
1gen crxer
Apr 28, 2004 04:37 PM
dwilson
Nov 12, 2003 07:46 AM
VanHonda
Nov 9, 2003 06:42 PM
Simple
Apr 8, 2003 05:26 AM
