LS TRANNY?
Old Nov 14, 2004 | 06:37 PM
cxVtecC1's Avatar
Default LS TRANNY?
ive heard that the ls tranny works good with boost, i have a b18c1 awaiting my turbo install and ive searched this topic but cant really find what im looking is this true or is there something in a certain setup that makes this combo work right?
Old Nov 14, 2004 | 06:42 PM
95GSRTT
Guest
Posts: n/a
Default Re: LS TRANNY? (cxVtecC1)
gsr is the best all around tranny if you ask anyone. But if you are sure you want an LS, I got one ill trade you for .
Only reason an LS would be better is for gas mileage and for highway/topspeed runs. And the GSR tranny can be remedy for that by just putting in an LS 5th.
Old Nov 14, 2004 | 06:43 PM
turboEGhatch's Avatar
****, search. This has been covered a dozen-ish times before on here.
The B18B tranny with longer gears being better for boost is a retarded myth that got started somehow. Shorter gears means quicker acceleration, I don't give a **** if it's a turbocharged, supercharged, naturally aspirated, or nitrous motor, it will be quite a bit quicker with a GSR tranny than it would with an LS tranny.
nonvtecD's Avatar
It's a myth, don't listen to those fools. Shorter gears equals faster car period.
Old Nov 14, 2004 | 06:46 PM
havalilsi's Avatar
Default Re: LS TRANNY? (turboEGsedan)
https://honda-tech.com/zerothread?id=770773
https://honda-tech.com/zerothread?id=762108
Old Nov 14, 2004 | 06:53 PM
95hatch-NK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboEGsedan &raquo;</TD></TR><TR><TD CLASS="quote">****, search. This has been covered a dozen-ish times before on here.
The B18B tranny with longer gears being better for boost is a retarded myth that got started somehow. Shorter gears means quicker acceleration, I don't give a **** if it's a turbocharged, supercharged, naturally aspirated, or nitrous motor, it will be quite a bit quicker with a GSR tranny than it would with an LS tranny.</TD></TR></TABLE>
he's a jerk for not searching, but you're a jerk for responding like that, two wrongs don't make a right.
Old Nov 14, 2004 | 06:58 PM
dornon13's Avatar
Default Re: LS TRANNY? (86hatchfire)
if you can get traction with the shorter gears you will ALWAYS be faster if you dont redline your longest gear (run out of RPM)
Old Nov 14, 2004 | 06:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86hatchfire &raquo;</TD></TR><TR><TD CLASS="quote">
he's a jerk for not searching, but you're a jerk for responding like that, two wrongs don't make a right.</TD></TR></TABLE>
The **** I am, atleast I answered him, instead of your cockrag attempt to try and make me feel bad or scold me or some **** like that.
Old Nov 14, 2004 | 07:15 PM
cxVtecC1's Avatar
it was my bad an i got my answer so thanx for the constructive critism,and thanx for tryin to be mister nice guy but im still learning how to use this damn computer
Old Nov 14, 2004 | 07:27 PM
cxVtecC1's Avatar
hers the deal my gsr tranny has a small crack in it.. will the internals fit say. an ls tranny case , is the case of the tranny the same with just the gears and fd being different,or does anyone have an empty tranny for building for sale?
Old Nov 14, 2004 | 08:08 PM
95GSRTT
Guest
Posts: n/a
a case is a case....
Old Nov 14, 2004 | 09:03 PM
cxVtecC1's Avatar
Default Re: LS TRANNY? (95GSRTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT &raquo;</TD></TR><TR><TD CLASS="quote">a case is a case....</TD></TR></TABLE>gotta learn somehow... thanx
Old Nov 14, 2004 | 09:34 PM
Mach1's Avatar
This is a whole diff world but in mustang land people pickup time going with a lower gear ratio because they are not able to build full boost before they have to shift with a high gear ratio, most switch from a 4.1:1 final drive to 3.23:1/3.08:1
Old Nov 14, 2004 | 09:55 PM
pimpintyperintegra's Avatar
i would say use a type-r or gsr tranny for drag racing
and use the LS for highway or any other time you want long gears--or at least put the LS 5th in the gsr
remember that if you top out before your opponent, you lose unless you agreed on a certain mph or place that is a win
that's just my opinion
basically it depends on what you intend to do with the car.
Old Nov 15, 2004 | 09:03 AM
Default Re: LS TRANNY? (Mach1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach1 &raquo;</TD></TR><TR><TD CLASS="quote">This is a whole diff world but in mustang land people pickup time going with a lower gear ratio because they are not able to build full boost before they have to shift with a high gear ratio, most switch from a 4.1:1 final drive to 3.23:1/3.08:1
The difference is if you take a stock 302 and bolt on a pair of T3's you're making sizeable boost at 3000 RPM's and the motor starts to quit at 5500 with E7's and a stock cam. Since a lot of people run C4's you're totally running out of gear with a 26" tire and 4.10's in any turbo mustang, which isn't the case with a B16 tranny and a high-revving motor. With an LS trans, 24.5 inch slicks, and an 8500 rev limit you will do 150 MPH in fourth gear, and you will be shifting out of third gear at 115 MPH, which is going to be very close to the traps for 99% of people. With a B16 trans/24.5" slicks/8500 rev limit you'll do 127 in fourth gear, which is ideal for most moderate to high horsepower turbo hondas. I personally feel the GSR is the best transmission for a street car that will be taken to the strip. On a typical 205/50/15 street tire fourth gear ends at about 128 which will let you make a full pass without shifting into fifth, but on slicks you're shifting out of third at 103, which isn't so obscenely close to the traps that you lose some speed. The only reason I would run an LS trans in a street turbo honda is if I were building an LS motor with stock cams where the power dies off dramatically on the top end and you arn't going to be shifting any later than 7000, maybe 7500 if you're running a lot of boost.
whiteyGSR
May 20, 2004 06:51 PM
itz_nij
Mar 15, 2004 05:26 PM
crazed_crx
Dec 4, 2003 07:28 AM
zbower7
Aug 21, 2003 04:08 PM
JDubya
Jul 3, 2003 10:04 PM
