IC on NSX ???? where does it go
Old Nov 14, 2004 | 09:13 PM
mrDFWmechanic's Avatar
Default IC on NSX ???? where does it go
just curious on where someone would mount the intercooler on an NSX ? would it go on top of the motor in the rear or would they mount it in the rear bumper between the exhausts or like how its usually mounted on the front. or do they not even need one, this is just a late night ? i just got
Old Nov 14, 2004 | 09:34 PM
dornon13's Avatar
Default Re: IC on NSX ???? where does it go (iROCKtheSOHC)
saw one in a mag with it under the rear bumper
Old Nov 14, 2004 | 09:39 PM
i wanna see some pics of that then ? would it even get air since its in the back of the car. like the toyota mr2 has those intakes that extend to the sides of the car to get air.
pimpintyperintegra's Avatar
they may be able to use the side vents and mount one if it is a single turbo or one on each side if it is a twin turbo set-up
probably the same set-up as you would do on a mr2 turbo
air to water may be a better option as well
do you have an NSX or are you just curious?
Old Nov 14, 2004 | 11:06 PM
O3DigitalBath's Avatar
Default Re: (iROCKtheSOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iROCKtheSOHC &raquo;</TD></TR><TR><TD CLASS="quote">i wanna see some pics of that then ? would it even get air since its in the back of the car. like the toyota mr2 has those intakes that extend to the sides of the car to get air. </TD></TR></TABLE>
arn't those only on the N/A mr2s?
i've seen scoupes on the top of the car for NSX's and i've also seen in the rear bumper...and air would get to the rear bumper....think about, thats why people cut holes, so the air doesn't get caught.
...do a search, or just check out the NSX forum, there are plenty of pics.
88_hatch_ls
Mar 1, 2012 09:58 PM
BobbyRodriguez
Other Make Vehicles
Feb 26, 2012 03:43 AM
Prudz_lude
Oct 19, 2006 12:52 PM
nuttybumpo
Aug 22, 2006 02:22 PM
H.crx-si
May 16, 2004 07:23 AM
