h22 turbo oil feed line
the oil feed line on my turbo will not be on top of the turbo when it is bolted to the manifold. will this cause a problem. and if so how do i fix it? when i bolt the turbo up the oil feed line will be pointing to the motor and the drain line will be pointing to the radiator support., what do i do?
Re: (americ_ian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by americ_ian »</TD></TR><TR><TD CLASS="quote">there is a way to turn ur housing around</TD></TR></TABLE>
Yes...You can turn your housing around to wich ever angle you want it to be.
-Lor
-Lor
