JG weld on fitting???
Old Nov 15, 2004 | 03:26 PM
Andyb22g's Avatar
Default JG weld on fitting???
ok so i was talking to my local import shop about my custom kit i am building and somehow we ended up talking about the return line fitting in the oil pan, and he told me that it would be fine to JB weld the fitting in!! is this really ok, or shoulld i acctualy get it welded in?
Old Nov 15, 2004 | 03:31 PM
diputs's Avatar
Default Re: JG weld on fitting??? (Andyb22g)
yeah, but if you're going to do that, get a no-weld fitting...less ghetto than JB... Personally, I'd just get one permanently welded. It's a big deal to turbo a car right. I wouldn't cut corners on something like an oil fitting.
Old Nov 15, 2004 | 03:32 PM
oxSLEEPERxo's Avatar
i have seen people jb weld it and it works fine for them. if you have the money to get it welded, get it welded, that is what i would do to be on the safe side.
Old Nov 15, 2004 | 04:23 PM
PrettyLude's Avatar
weld it, to ensure no possible leaks
Old Nov 15, 2004 | 06:13 PM
Mag00n's Avatar
Default Re: (PrettyLude)
Don't be a cheap bastard. Sure it has worked for some people but it's a half-*** thing to do. It costs me $30bucks to have my fitting welded on to my pan.
JB Weld
Old Nov 15, 2004 | 06:49 PM
Sinner's Avatar
I jb welded my y8 oil pan and it was perfect, I jb welded my d15b oil pan and it sucked, i tried many coats, I just gonna weld it now.
jb works great when its works, but when it drips.. it sucks...
Old Nov 15, 2004 | 07:11 PM
Tad's Avatar
Tad
the way I look at it,
you're going to have to pull the oil pan to put the return in anyways.
so if it's off the car, just drive it down to an exhaust shop or something and have the fitting welded solid.
i can't imagine they'd charge more than 20bux to do it. if not less.
but yeah, I have heard of people jb welding it and it working.
BUT I have also heard of people jb welding it and it leaking !!
Old Nov 16, 2004 | 05:02 PM
PrettyLude's Avatar
if you can afford to go turbo, i don't see how you can be so cheap and use jb weld on there
Old Nov 16, 2004 | 05:11 PM
BB6-213's Avatar
I used JB on my H22 oil pan because it is aluminum, and honestly, it worked great, just take your time and make sure to let it cure good and you will be set.
Old Nov 16, 2004 | 05:13 PM
93turbo16's Avatar
I welded mine to the pan, and then sealed it up with RTV to prevent any leaks. Works like a charm.
Old Nov 16, 2004 | 06:36 PM
deeweewoo's Avatar
No weld fitting $5 parts at Autozone GOOD
Weld on fitting $10 & JB Weld $5 from Wal-Mart $15 BETTER
Weld on fitting $10 & Weld Job from a pro $20 $30 BEST
Its Your Call Done right they will all perform the Same.
(Dont Quote me on Prices)
turbo-crx
Feb 27, 2009 09:30 AM
pitoracing24
Dec 4, 2007 04:05 PM
CATCH DIS HATCH
Apr 14, 2004 08:50 PM
Mr. Softee
Sep 18, 2003 08:09 PM
Evil EG
Apr 3, 2002 07:30 PM
