mod my head or do ls/vtec...more to the situation...
Old Nov 18, 2004 | 08:32 AM
NobodySpecial's Avatar
Default mod my head or do ls/vtec...more to the situation...
i've only been boosting about a month now and i already have a slight problem. I recently did another compression test on my ls and it came up 125, 170, 170, 165. I havn't been pinging the rev limiter but i'm sure my friends have so i'm guessing i probably have a bent valve. I figure if i'm gonna fix that and if the head is already off, should i just do a ls/vtec conversion or modify the current head for better flow. Save some money on some machine work and head gasket i guess...
Current setup:
-my own built kit with a revhard mani and t3/t4 turbo
-38mm tial pushin .5 bar (no boost controller yet...)
-fmu, walbro 255 fuel pump (was saving up for hondata w/boost but...head first)
-3" all the way back
Engine: stock ls with about 100k on it [i've been the only owner, i baby it but my friends beat it up ]
Goals:
-eh...nothing high. 250whp with reliability(does this mean no ls/vtec turbo?).
if i do go ls/vtec, i got a really nice moroso valve cover for sale!
Old Nov 18, 2004 | 04:14 PM
Default Re: mod my head or do ls/vtec...more to the situation... (NobodySpecial)
BUMP...any advice is good. specially from the Expertz ;P
Old Nov 18, 2004 | 04:28 PM
hondaguyef's Avatar
Everyone is going to tell you to go w/ the VTEC head but, I am a non-vtec lover so, NON-VTEC all the way .
Relaibility is in the hands of the builder and tuner in either situation. If you don't want to spend a ton of money just get the valve(s) fixed and 250 WHP should be a realistic goal w/ your current setup.
Phil
Old Nov 18, 2004 | 06:20 PM
Rod.'s Avatar
Default Re: mod my head or do ls/vtec...more to the situation... (hondaguyef)
I respect the ls(had 2 ls turbos). Before I joined this site I thought you can get high horsepower with only vtec. I see doing all that machine work to the head probably end up costing me more than a vtec head. Which teh vtec heads are already good flowing from the factory.
Old Nov 18, 2004 | 08:20 PM
Default Re: mod my head or do ls/vtec...more to the situation... (redturbocivic)
thanx for your input, but hmm...vtec or no vtec?
Old Nov 18, 2004 | 11:41 PM
PrettyLude's Avatar
yes it would be better with the vtec head
Cyphear
May 3, 2007 09:35 PM
92lsVtecTeg
Dec 25, 2006 05:24 PM
BDogggUT34
Feb 11, 2005 02:02 PM
DriveSlowHomie
Jan 26, 2005 08:59 AM
airwalk07143
Oct 21, 2004 09:55 PM
