00' civic si B16a2 fuel pressure??
Old 11-14-2004, 10:18 AM
VspecSiR's Avatar
Default 00' civic si B16a2 fuel pressure??
what is the stock fuel pressure setting?
Old 11-14-2004, 11:35 AM
b16ahybrid's Avatar
Default Re: 00' civic si B16a2 fuel pressure?? (VspecSiR)
36psi +/- 2psi
Old 11-14-2004, 12:23 PM
VspecSiR's Avatar
Default Re: 00' civic si B16a2 fuel pressure?? (b16ahybrid)
what fuel pressure reg is recommended? I have a mild turbo setup. Greddy turbo, and currently boosting 6psi. I want to turn it up to 7-8psi (on stock internals) but want to make certain i have adequete fuel.
Is a walboro 255lph (high pressure) fuel pump a bit of overkill??? this car is not a race car, could i get away with the 190lph (hp)? I also wanted to get a better fuel rail any suggestions as to what brand. And if necessary, get larger injectors (370 or 440cc).
my goals are for a 200-220whp via Hondata. here is what i wanted to get
-Walbro 255lph (HP) in tank fuel pump (worried if this is too overkill for my setup)
-Edlebrock or AEM Fuel Rail
-Adjustable Fuel Pressure Reg. (not sure what brand would be good)
-Larger Injectors (currently using 310cc, someone told me i'm pushing the limits at 6psi with the 310cc injectors. Should I get larger ones?)
Old 11-14-2004, 05:12 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VspecSiR &raquo;</TD></TR><TR><TD CLASS="quote">
-Larger Injectors (currently using 310cc, someone told me i'm pushing the limits at 6psi with the 310cc injectors. Should I get larger ones?)</TD></TR></TABLE>
Stock fuel pressure, regulator, and rail works just fine.
I'm also using the 255lph HP..works fine, but I have to use a aem fpr to lower my fuel ressure at idle.
You are going to want to use larger then 310cc injectors.If your going with hondata get at least 440cc or larger.
Old 11-16-2004, 09:02 PM
VspecSiR's Avatar
I want to get all the things i need to buy out of the way first before i get hondata. so for the time being would my car idle fine with the 440cc injectors?
Old 11-17-2004, 06:38 AM
i my honda
Global Mod
White Smoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VspecSiR &raquo;</TD></TR><TR><TD CLASS="quote">I want to get all the things i need to buy out of the way first before i get hondata. so for the time being would my car idle fine with the 440cc injectors? </TD></TR></TABLE> Not without anything to turn down the fuel
Stock rail and regulator are fine
Dont get the 190 it is not what you want! You want 255 or 255HP; it's not overkill
01PYTypeR#1140
04-08-2007 03:14 PM
Cyphear
02-24-2007 01:42 PM
endlessdv
01-09-2006 12:47 PM
aalb1
11-02-2005 10:47 AM
Red D Dragon
34
04-05-2004 04:51 PM
Quick Reply: 00' civic si B16a2 fuel pressure??
