ic endtanks and the advantages?
Old Nov 17, 2004 | 04:33 PM
redboost10's Avatar
Default ic endtanks and the advantages?
i was just wondering does the shape of the end tanks on a ic play a huge roll of the motion of the air. i have a pwr with just squarish end tanks, not slanted like a few out there. and with 14 psi, my 24*8*3 ic, from the temp of the pipes on both sides, was pretty effecient. do thise slanted end tanks play a huge roll or nothing big? also im planning to turn up the boost to about 20 psi. will my pwr 24*8*3 ic be ok? thanks guys
Old Nov 17, 2004 | 08:56 PM
redboost10's Avatar
Default Re: ic endtanks and the advantages? (tgh99si)
does anyone have an input?
Old Nov 17, 2004 | 08:59 PM
raene's Avatar
Yes, it does play a good-sized role, and yes, you do want tapered tanks over square. But the important part is of course to test system efficiency after install - measure pressure drop across the intercooler and if that tests out acceptable to you, forget about it!
Old Nov 17, 2004 | 09:24 PM
redboost10's Avatar
Default Re: ic endtanks and the advantages? (raene)
how the heck do i measure pressure drop
Old Nov 18, 2004 | 01:44 AM
integlspwr2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">how the heck do i measure pressure drop</TD></TR></TABLE>
with a really good EMS.
Old Nov 18, 2004 | 02:30 AM
liam821's Avatar
25 Year Member
Default Re: ic endtanks and the advantages? (integlspwr2k)
Put a boost gauge on each side of the FMIC. There is a bling boost gauge out there that has two inputs that reads on the same guage - i thought it was greddy but i cant find it on their site.
But using a "bling ems" would be a better option because then you can datalog the results insteading of guesstimating the differences.
liam
Old Nov 18, 2004 | 08:41 AM
redboost10's Avatar
Default Re: ic endtanks and the advantages? (liam821)
ok, thanks guys.
Home Wrecker
Feb 26, 2006 05:35 PM
bambam
Mar 27, 2005 04:53 PM
RNPoo7
Mar 8, 2005 11:46 PM
superduperman
Jul 9, 2003 03:37 PM
integranator
Nov 22, 2002 12:37 AM
