Drag manifold.... Tial or internal wastegate?
Ok i got a killer deal on a new drag manifold. I have heard many horror stories with boost creep due to the positioning of the wastegate on the mani. I plan on only boosting 7psi with a goal of around 230-250whp. I will be running a 2.5 dp, 2.5 test pipe, to a 60mm exhaust (will go 2.5 later).
So will i be better off using my internal wastegate or going with a 38mm tial???
TIA
TIA
Re: Drag manifold.... Tial or internal wastegate? (That4drGSR)
as long as your don't go 3inch exhaust you shouldn't have a problem at 7psi and making your hp goals 230-250hp... But peronally, when I went from DRAG to INLINEPRO I noticed such a "huge" difference I would never use a drag manifold again!
Re: Drag manifold.... Tial or internal wastegate? (9psiTurboSI)
I had actually read your post from awhile back! So it starts spiking when you go with a 3" exhaust only right?
I dont plan on going above 7psi until i get a block built.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by That4drGSR »</TD></TR><TR><TD CLASS="quote">
In my case... that's correct, I had the drag 2.5in dp-oem cat-60mm exhaust to 2.5in dp-2.5-3in test pipe-3inch thermal and all hell broke loose!
Absentmind
Mid-Atlantic (Sales)
09-29-2008 05:53 PM
Spooled1.6L
04-17-2004 08:53 AM
