O2 Sensor on 96-00 Civic Wiring Harness HELP!!!
incase the big one doesn't work
I dont want to run a cable from my old o2 sensor into my cabin, i'd like to just use the wires that are allready run to my ecu. I do not see an o2 on that pinout. Can anyone help?
I drive a 99 Civic Si. Thanks in advance!
Also, i'm wiring up my Zeitronix Wideband, it has a wiring setup like so
red switched power (ex. ignition)
white wideband analog out (wont be using this)
Green RPM input (0-5v square from tach)
Orange Boost sensor in
Yellow Boost sensor +5v pwr.
Black Power ground
Brown Sensor ground
Purple 02 sim (to ecu)
Grey TPS sensor
Brown Sensor ground (again)
Blue User input (0-5v)
Help me, i dont know how to wire about half of this. Do i connect the red wire to an acc pin on the ecu? please help.
Modified by Si Shane at 9:55 AM 11/13/2004
Re: O2 Sensor on 96-00 Civic Wiring Harness HELP!!! (Si Shane)
Last step, turbo kit is on. Car runs and idles fine, i just cannot boost without a boost gague/wideband!! I really want to run the car hard, lol.. ANy help is VERY MUCH appreciated. Thanks!
For the primary O2 sensor the wires go to connector C pins 1 and 15.
For the secondary o2 sensors the wires go to connector A pins 8 and 23.
