If you had sleeving job, can you get it re-sleeved?
I know you can, but the question is .. Are there any draw backs from re-sleeving a motor that has already been sleeved?
I've always wondered this...
Re: If you had sleeving job, can you get it re-sleeved? (b00sted93Hatch)
when i had AEBS sleeves installed in my motor, the guy doing the work said that i was possible to do this and he never mentioned that anything bad would happen. im sure if the process is done correctly u shouldnt have any trouble with it at all.. and i know they make replacement sleeves on the market..
why would you resleeve it tho??
Re: If you had sleeving job, can you get it re-sleeved? (TurboBumblBee)
I'm just asking to ask ... if you want an example... lets say you had brand "AEIOU" Sleeves and they sunk.
Re: (lanojp1)
You can knock Benson sleeves out and reinstall new ones. Does not hurt the block. However. you cannot take a previously sleeved block and install Bensons in it as Benson takes out less material than other installed sleeves.
Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl »</TD></TR><TR><TD CLASS="quote">You can knock Benson sleeves out and reinstall new ones. Does not hurt the block. However. you cannot take a previously sleeved block and install Bensons in it as Benson takes out less material than other installed sleeves.</TD></TR></TABLE>
That's why Benson Sleeves are top notch
