what temperature ...
Old Nov 15, 2004 | 04:27 AM
kameleonjrsc's Avatar
Default what temperature ...
i need to know at what temperature is the engine block and head on a b18c1 with jrsc or without jrsc????
because i'm looking to spray paint my engine block and head , but this new special paint is only good to about 250 -300 degrees farenheit!!!!
do you think that since it runs with a 160 degree thermostat, that the engine exterior case temperature is much higher than that??????
anyone care to measure their engines casing temp with maybee a digital thermometer or pyrometer???? ny car is already stored for the winter!!!!!
thank you in advance.
Old Nov 16, 2004 | 03:23 AM
Default Re: what temperature ... (kameleonjrsc)
ttt
Old Nov 16, 2004 | 04:32 AM
RacerXI's Avatar
That's not goin to cut it. There are special paints made for engine blocks/heads.
Old Nov 16, 2004 | 07:31 AM
Default Re: what temperature ... (RacerXI)
??? you really think that an engine block goes above 300 degrees farenheit!?!?!?!?
did or can anyone take a temp reading?????????!!!!!!!???
Old Nov 16, 2004 | 08:04 AM
Boost Addict's Avatar
Default Re: what temperature ... (slow poke)
You're going to need higher temp paint then that. More like 1200-1500 degrees.
Old Nov 16, 2004 | 01:24 PM
Default Re: what temperature ... (xPRELUDEx)
it wont flake , the worst itll do is fade!!!!
i currently have it painted with automobile paint ( 2 years) and it did not flake!!!!
it only faded a little bit, currently looknig for a better clear coat!!
just need to know around what temp?!?!?!?!
mikej94civex
18
Jan 20, 2010 05:38 PM
b20beast83
Paint and Body
May 15, 2009 06:01 PM
Jintegragsr97
Jul 30, 2008 08:25 PM
swappedcx
Paint and Body
Aug 13, 2007 05:52 PM
djphonics
Dec 18, 2006 02:02 PM
