Wastegate Problems
I need opinions on that.
I have my Tial wastegate pressure line connected to the turbo compressor discharge outlet.
I want to know if it makes any difference whether the pressure line is connected to the turbo discharge outlet or just before the throttle plate like Tial recommends?
Thanks ahead!
Thanks ahead!
if by before the throttle plate you mean on the charge pipe then it'll make no difference.
if you mean on the intake manifold and you have no boost controller then you will see 1 or 2 more psi since it'll compensate for pressure drop through the charge piping.
VerbalKint
Dec 21, 2002 06:03 AM
