b20vtec turbo... no vtec?
Old Nov 14, 2004 | 01:59 PM
hybridpatient95's Avatar
Default b20vtec turbo... no vtec?
so we installed my friends turbo in his b20vtec civic and we take it for a test drive and the vtec isnt kicking in. the plug was connected and everything but it just wasnt going. when we tapped it for the oil for the turbo we just put a tee at the end of the vtec line and ran it to the turbo. do you think the vtec isnt kicking in cuz of the lack of oil pressure? is there a way we can make the pressure go up? my friend is running a p28 chipped and vafc controller. please help..
Old Nov 14, 2004 | 03:09 PM
joey1320's Avatar
Default Re: b20vtec turbo... no vtec? (kinkbmx159)
out of topic but do you want the b16 head I have? I tried to get a hold of you(pm'd) but you didn't respond.
I still have it let me know!
Old Nov 14, 2004 | 03:17 PM
Default Re: b20vtec turbo... no vtec? (joey1320)
umm nah my friend doesnt need it yet but soon.
now does any one know whats wrong with my friend whip??
Old Nov 14, 2004 | 03:20 PM
joey1320's Avatar
sorry I'm using this as a way to talk to you but okay... if you need it let me know and if i still have it we can go from there.
Old Nov 14, 2004 | 03:23 PM
iiight np man...now does any one know whats wrong with my friend whip??
Old Nov 14, 2004 | 03:28 PM
joey1320's Avatar
install a oil pressure gauge and see what it reads... in my CRX it went up to 60psi at 7000rpm.
if you don't see a good amount of pressure, that's your problem.
Old Nov 14, 2004 | 03:33 PM
whats a good amount of pressure? did you have the golden eagle sandwich plate or did you have just straight up fittings and tee's??
Old Nov 14, 2004 | 03:35 PM
hOndafienD 04's Avatar
wheres the easiest place to get a oil pressure reading?
Old Nov 14, 2004 | 03:37 PM
joey1320's Avatar
it was just tee fittings and hoses. but i didn't have a vtec head it was just a ZC engine. anyways at full throttle i saw 60psi+ of oil. around 4800rpm it was about 45psi. It has got to be somewhere around there for your vehicle. good luck
Old Nov 14, 2004 | 03:43 PM
ok...will be doing this 2morrow. can i install a smaller oil filter to increase oil pressure...is this safe?
Old Nov 14, 2004 | 03:44 PM
TurboedGSR's Avatar
the opening is too small to flow 80psi. a sanwich adapter will fix it. be sure to add a orifice on the turbo feed line to lower the pressure
rextec's Avatar
did you install a vtec oil pump?
Old Nov 14, 2004 | 03:45 PM
we did not build the b20/vtec...we just turboed it, and it was wroking b4 the turbo set up...so a smaller filter isnt a good idea?
Old Nov 14, 2004 | 03:51 PM
speedtec11s's Avatar
Default Re: (hOndafienD 04)
COol
Old Nov 14, 2004 | 03:53 PM
Default Re: (speedtec11s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedtec11s &raquo;</TD></TR><TR><TD CLASS="quote">COol</TD></TR></TABLE>
what? *** off!
Old Nov 14, 2004 | 05:14 PM
Boosted Chemist's Avatar
Default Re: (rextec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rextec &raquo;</TD></TR><TR><TD CLASS="quote">did you install a vtec oil pump?</TD></TR></TABLE>
maybe the turbo isnt getting enough oil also , i would look into oil pressure before u burn out your turbo
Old Nov 14, 2004 | 05:40 PM
we will be checking out the oil pressure 2morrow....will a smaller oil filter increase pressure...or thicker oil? we are running on 10w 40 right now
Old Nov 15, 2004 | 07:03 AM
if we didnt have a vtec oil pump i dont think the vtec would work at all. right??
Old Nov 15, 2004 | 10:50 AM
rextec's Avatar
it would prob. work but the extra line feeding the turbo would drop the oil pressure some more. just check it with a guage first....
Old Nov 15, 2004 | 11:12 AM
true man
Old Nov 16, 2004 | 04:16 PM
Default Re: (kinkbmx159)
bump man !!
Old Nov 16, 2004 | 04:23 PM
Mag00n's Avatar
Stop bumping both of these threads. Pick one and let the other one die
https://honda-tech.com/zerothread?id=1055600
Old Nov 17, 2004 | 02:37 PM
Default Re: (Mag00n)
boo im just trying to get some answers quick. some people only look at one forum not all of them. so i did this to get the word out. gotem
(Anthony)
12
Jul 8, 2005 03:26 PM
hybridpatient95
Nov 16, 2004 04:15 PM
mrbsponge
Sep 25, 2004 11:55 AM
troubledsol03
Jun 22, 2004 01:37 PM
DXK Eg
Mar 31, 2004 10:58 AM
