autometer boost gauge
Old Nov 17, 2004 | 07:33 PM
ViruSi's Avatar
Default autometer boost gauge
Hey guys I got a mechanical autometer ultra lite boost gauge that is not hooked up but it's sitting at 1 psi? Is this normal? Also anyone know where to find the 1/8" connector to connect the nylon hose to a T-fitting? Thanks.
Old Nov 17, 2004 | 07:45 PM
lanojp1's Avatar
Default Re: autometer boost gauge (ViruSi)
Go to autozone of the likes and ask for a soft vacuum connector...
Old Nov 17, 2004 | 08:58 PM
ViruSi's Avatar
Default Re: autometer boost gauge (lanojp1)
thanks...bump anyone know if the gauge is messed up since it's reading 1psi already?
Old Nov 17, 2004 | 11:09 PM
VspecSiR's Avatar
yea, your boost gauge is messed up
Old Nov 18, 2004 | 02:35 AM
liam821's Avatar
25 Year Member
Default Re: autometer boost gauge (VspecSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VspecSiR &raquo;</TD></TR><TR><TD CLASS="quote">yea, your boost gauge is messed up</TD></TR></TABLE>
Ive seen a bunch of gauges that read at 1psi. Its not supposted to do that - however it will prolly read just fine - just 1psi off.
liam
Old Nov 18, 2004 | 08:48 AM
opto_isolator's Avatar
Those gauges work fine - but will easily foo up if you "squeeze" the casing. I did this by accident on mine. The bourdon movement inside is very sensitive. If you GENTLY squeeze the casing at various points you should get the thing to move back to zero.....
Old Nov 18, 2004 | 08:50 AM
MooreBoost's Avatar
Default Re: autometer boost gauge (opto_isolator)
Get a new gauge. Autometer is garbage.
Old Nov 18, 2004 | 10:15 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ViruSi &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys I got a mechanical autometer ultra lite boost gauge that is not hooked up but it's sitting at 1 psi? Is this normal? Also anyone know where to find the 1/8" connector to connect the nylon hose to a T-fitting? Thanks.</TD></TR></TABLE>
I recommend not running the nylon line if at all possible. I'm running 1/4" ID fuel hose [eventually to be replaced with 1/4" ID silicone hose] for my gauge. Just need a brass female 1/4" NPT to 1/4" hose barb fitting and some teflon tape. If you need the fitting, I think I have a few left...let me know. 1/4" ID hose offers better gage response, and less problematic with kinking and holes than that piece of **** nylon hose they give you.
Old Nov 18, 2004 | 10:21 AM
StrokedPSI's Avatar
Default Re: autometer boost gauge (liam821)
It'll read just fine, it is probably seeing a little friction inside, when you plug it into a vacuum source it'll be fine. After it sees vacuum it should go back to the "0" area. Mine was the same way and it corrected itself.
Old Nov 18, 2004 | 10:38 AM
Alchemist's Avatar
Default Re: autometer boost gauge (StrokedPSI)
Autometer is garbage. I had the same problem with a boost gauge, sent it back. They gave me a new one and after a month it has the same problem that youre having.
Old Nov 18, 2004 | 11:07 AM
StrokedPSI's Avatar
Default Re: autometer boost gauge (Alchemist)
if they're garbage like you and so many other people claim, why do pro racers use them in cars that cost well over the 100k's mark??? How come you don't see the pro's with a defi or a greddy?
Old Nov 18, 2004 | 01:00 PM
Alchemist's Avatar
Not the same gauges buddy. The pro's arent using the same $50 Autometer gauges that all of us are using.
Old Nov 18, 2004 | 01:34 PM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StrokedPSI &raquo;</TD></TR><TR><TD CLASS="quote">if they're garbage like you and so many other people claim, why do pro racers use them in cars that cost well over the 100k's mark??? How come you don't see the pro's with a defi or a greddy?</TD></TR></TABLE>
Thats like saying BAR runs D16's.
Old Nov 18, 2004 | 02:18 PM
fast94ex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alchemist &raquo;</TD></TR><TR><TD CLASS="quote">Autometer is garbage. I had the same problem with a boost gauge, sent it back. They gave me a new one and after a month it has the same problem that youre having. </TD></TR></TABLE>
The gauges do that after being shipped etc., once you hook it up and it reads vaccum it would be fine. Autometer is not garbage, and yes the gauges you buy for your car are the same the pros are using. No one i know including myself has ever had a problem with them, including several 7 and 8second cars. IMO paying double or triple the price of autometer gauges to get some that look better or have cool features is garbage. Use what works.
Old Nov 18, 2004 | 02:40 PM
MooreBoost's Avatar
Default Re: autometer boost gauge (fast94ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast94ex &raquo;</TD></TR><TR><TD CLASS="quote">
Use what works. </TD></TR></TABLE>
Greddy.
All three of my Autometer gauges sucked. Both of my GReddy gauges are awesome.
Just a coincidence I guess.
Old Nov 18, 2004 | 03:27 PM
blackeg's Avatar
Default Re: autometer boost gauge (tegunderpressure)
count me in as another boost gauge that read 1 psi. my gauge would sometimes also have the 2 brass threads in the back for mounting come loose and go back into the gauge, not allowing it to read vacuum. it was a big pain in the ***, but the gauge was free.
Old Nov 18, 2004 | 04:47 PM
ViruSi's Avatar
Default Re: autometer boost gauge (blackeg)
I hooked my gauge up to day and after driving around a lil' bit in vacuum it's almost back to normal. It's still slightly leaning towards 1 psi, but it's getting better. Thanks for the replies.
Old Nov 18, 2004 | 06:32 PM
djfob's Avatar
1 psi isn't bad since mine reads 4 psi when my car is off....I just compensate and subtract 4 from the reading which is a hassle
Old Nov 18, 2004 | 07:47 PM
sleeping GIANT's Avatar
Default Re: autometer boost gauge (djfob)
try reading -10 vac. when off, mine slowly got worse and I sent it back for # 2 , I think I sqeezed mine in the dash to hard. I ordered a pillar mount for the new one!
skuded
Apr 21, 2011 04:38 PM
threatcon13
Feb 3, 2002 01:23 AM
