Oil leak??
Old Sep 22, 2005 | 06:26 PM
weak_sauce's Avatar
Default Oil leak??
I just install my greddy turbo kit on my b18c1, the boost is at 6, and while i was driving, the car started to smoke up, pulled over and check, there were oil all over the back of the block. Today we are going to spray down the motor and let the car run to see where it is leaking from, it might be the T fitting that we tap for the oil feed, or the oil pan...that all i can think of?? any suggestions?
Old Sep 23, 2005 | 11:51 AM
DJ Gurgla GSR's Avatar
Default Re: Oil leak?? (weak_sauce)
most likely the oil feed based on where you described the oil being. I don't think if the pan was leaking it would be all over the back of the block. May need some teflon tape on the fittings
Old Sep 23, 2005 | 01:57 PM
nfn15037's Avatar
Default Re: Oil leak?? (DJ Gurgla GSR)
Probably spraying out of the PCV box.
Old Sep 24, 2005 | 03:55 AM
DARKSIDE_TEG's Avatar
i had same problem but mine was infront of the engine too, i believe its my Valve cover.. i am pretty sure, but i also had it leak from my oil drain line b4.
Old Sep 24, 2005 | 07:40 AM
no2unenolife's Avatar
if its comin from the back i'd say T fittings
Touge Tuning
May 2, 2008 05:27 AM
weak_sauce
Sep 22, 2005 10:03 AM
not2slo128
Sep 21, 2005 09:23 PM
LSVtechnologytur...
Sep 17, 2005 01:46 PM
Nextelbuddy
Oct 3, 2003 01:51 PM
