advice needed on gsr setup
Old Sep 24, 2005 | 05:52 PM
fkneh's Avatar
Default advice needed on gsr setup
I have 95 gsr with 60,000 miles
heres what I already have
mitsu TDO5
stock flanged manifold
blitz bov
fmic
255 fuel pump
550cc injectors
ngk bkr7e and wires
getting either s200 or uberdata
6 puck sprung clutch
boost controler
Should i buy cometic head gasket and headstuds even if I will only see low boost?
planning on 8lbs of boost
should that be enough for over 230whp?
any advice appreciated thanks
Old Sep 25, 2005 | 06:47 AM
TheShodan's Avatar
Moderator
Default Re: advice needed on gsr setup (fkneh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fkneh &raquo;</TD></TR><TR><TD CLASS="quote">I have 95 gsr with 60,000 miles
mitsu TDO5
blitz bov
fmic
255 fuel pump
550cc injectors
ngk bkr7e and wires
boost controler
Actually, as long as the motor is in good standing condition, the headgasket (as long as it is OEM) and studs aren't necessary for your turbo setup. Is the turbo you're using a GREDDY TD05 18G w/ the rectangular (T25) inlet flange? That one is good for about 250whp.
Old Sep 25, 2005 | 01:40 PM
fkneh's Avatar
Default Re: advice needed on gsr setup (TheShodan)
thanks
yah im really worried because it is not a greddy unit.
should i leave my vtec at 4400 or put it back to 5800?
since the turbo will be dropping off at higher rpm's I dont think ill make full use of vtec at 5800
Old Sep 27, 2005 | 02:11 AM
fkneh's Avatar
what kind of tdo5 do I have
49178-0520
030321032
where can I find a equal length manifold for my turbo
Old Sep 28, 2005 | 10:32 PM
fkneh's Avatar
Are saturated or peak and hold injectors better?
Modified by fkneh at 11:42 PM 9/28/2005
Rvkeg6
Dec 10, 2011 10:30 AM
ForgedSleeper
Mar 21, 2004 07:45 PM
mozez
Jan 13, 2004 08:48 PM
crxturboh22
Jan 12, 2004 01:55 AM
BoostedD15B7
Aug 8, 2002 12:26 PM
