boost making brake problems
Old Sep 24, 2005 | 01:56 PM
egcoupeautox's Avatar
Default boost making brake problems
i have a boosted d15 pushing 10lbs. it has done fine for three months but all the sudden the breaks started to grab by there self. after replaceing the master cyclinder and booster i come to fine out its the one way valve from the manifold to the booster. i replaced it with a orginal and it worked fine for about 10 minites and it did it again. so i went and got a heavy duty one from a truck, and the same thing happened. has anyone had this problem or know what i can do to fix it.
Modified by egcoupeautox at 3:41 PM 9/24/2005
Old Sep 24, 2005 | 08:40 PM
PYITR821's Avatar
Default Re: boost making brake problems (egcoupeautox)
did you connect a vacuum line before the check valve for the brake booster?
Old Sep 24, 2005 | 09:16 PM
airshifter's Avatar
shorten the throw from the back of your brake pedal just a little bit
Old Sep 27, 2005 | 03:34 PM
no the line is stright frome the booster to the manifold
Old Sep 27, 2005 | 03:37 PM
97turbols's Avatar
Default Re: (egcoupeautox)
you have to tee into the brake booster line before the check valve (inbetween the check valve and the intake manifold). Is this how you have it done?
Old Oct 16, 2005 | 06:23 PM
no there is nothing between the booster and the manifold.
Freshdot
Jun 18, 2010 06:34 PM
mikej94civex
May 11, 2010 08:39 PM
pjr710
21
Jun 11, 2008 12:33 PM
vtec-adykt
Mar 25, 2008 08:16 AM
Willie
Jan 28, 2005 08:28 AM
