Tach Jumping in higher rpms?? HELP
Old Sep 24, 2005 | 11:49 AM
turbotime's Avatar
Default Tach Jumping in higher rpms?? HELP
Hey i just got my turbo setup tuned and it runs real nice.
BUT
After i get into the vtec range (>5-6krpms) the tach jumps around like its losing signal or something. We had a similar issue on the dyno with the dyno tach losing signal trying to read off my spark wires.
I am going to get new plugs, wires, a cap and a rotor right now, do you think this will fix the problem or do you think i need a whole new distributor?
Thanks for the help! need advice asap
Old Sep 24, 2005 | 12:18 PM
livinlow's Avatar
Default Re: Tach Jumping in higher rpms?? HELP (turbotime)
When I first got mine together the tach jumped a little bit at around 7k with my plug gap at around .32, lowered it to .30 without changing anything else and fixed the problem. Maybe give it a try.
Old Sep 24, 2005 | 01:10 PM
Muckman's Avatar
Moderator in Chief
Dont waste your money plugs, wires, cap, rotor. None of it is responsible for the RPM signal. Sounds like your having an issue with the cam/crank sensors in the distributor.
Whats your ignition setup like?
Old Sep 24, 2005 | 05:01 PM
turbotime's Avatar
stock ignition
the tach reads perfect til about 6-7k+. Got some new sparks, rotor and cap, going to install now with a .3 gap, ill let you know how it goes
Think the dizzy itself might need replacing? The mechanics at the dyno said the bearing that spins the rotor can go bad after a while (original dizzy, 13yrs old) and that can loosen the bearing making the rotor lose contact at higher rpms, think this might be it?
Thanks
Old Sep 24, 2005 | 05:09 PM
nfn15037's Avatar
Default Re: (turbotime)
Cap, rotor, plugs, wires etc can all cause that, but the most likley culprit is a dying ignitor.
Old Sep 24, 2005 | 05:12 PM
Full-Race Geoff's Avatar
Default Re: (nfn15037)
agreed, generally a dying ignitor will definately do this, as it has fluctuating tach output.
Old Sep 24, 2005 | 05:14 PM
Adi Radoncic's Avatar
On Fire!
Check your engine grounds and make sure those are all tight.. That should be the first thing you look at plus its easy to fix if thats the problem. Check the ground wire that bolts down to the thermostat housing first.
Old Sep 24, 2005 | 05:31 PM
Muckman's Avatar
Moderator in Chief
I would try another dizzy.
Old Sep 24, 2005 | 07:02 PM
turbotime's Avatar
its deinfitely the dizzy, anyone got a b16 dizzy in MD?
Old Sep 24, 2005 | 07:37 PM
Blaze45's Avatar
Brrraaaap!
Another one for the ignitor....
Blaze
Old Sep 25, 2005 | 12:48 AM
abnaasefmb's Avatar
Default Re: (Blaze45)
dont even need to read. ignitor
Old Sep 25, 2005 | 01:16 AM
2muchboost2blow's Avatar
Default Re: (abnaasefmb)
mine started bouncing like that one time turns out i forgot to tighten the screws back down after adjusting timing at the distributor and it was halfway on... oops
Old Sep 25, 2005 | 10:25 AM
turbotime's Avatar
new dizzy, fixed!
Manny-EF
Jun 27, 2010 08:34 AM
Project X
Sep 15, 2007 02:56 PM
force-fed
May 9, 2006 05:05 PM
JDM-EJ698
May 5, 2006 02:35 PM
sincityEX
Nov 7, 2004 07:38 PM
