EF Top Mount Update
Old Sep 24, 2005 | 09:11 PM
ScottEK's Avatar
Default EF Top Mount Update
Some people were asking questions about my setup a few months ago and I really haven't had a chance to work on it since then. I finally dropped the motor back in tonight and mocked stuff up to take pictures again. Switching to the GSR block moved things around a little bit and the GSR oil pan interfered with my 4" down pipe. So there are still kinks to work out. Once the downpipe is fixed I'll throw the radiator back in to show those of you who were asking where it's going to go. Dadfab is currently working on making a hydro trans mount and I need injectors a few other small things. Should be up and running within a month though. Here's some pics:
Old Sep 24, 2005 | 09:37 PM
abnaasefmb's Avatar
Default Re: EF Top Mount Update (ScottEK)
Suddenly I don’t feel to motivated to post the pics of the fmic I mounted today. Oh and nice job
Old Sep 24, 2005 | 09:40 PM
G
sh!t happens.
Default Re: EF Top Mount Update (abnaasefmb)
Nice setup.. What type of numbers are you looking for?
Old Sep 24, 2005 | 09:45 PM
ScottEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">Suddenly I don’t feel to motivated to post the pics of the fmic I mounted today. Oh and nice job </TD></TR></TABLE>
Well your further than me then I have a sweet back door intercooler that has been sitting for about 6 months now. Cant wait to put it on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G"UNIT" &raquo;</TD></TR><TR><TD CLASS="quote">
Nice setup.. What type of numbers are you looking for?</TD></TR></TABLE>
That's a tough question, it's going to be tuned and ran on 100 unleaded, the closest gas station to me sells it so that works out nicely. I dont want to set my goals to high because this is the first engine I built and I dont honestly even know if it will run right but I would hope for 400-500whp and my goal from the begininng was a 10.99 or better.
Old Sep 24, 2005 | 09:47 PM
XxRoCkMaNxNEOxX's Avatar
looks nice man. let us know the update on the proj.
Old Sep 24, 2005 | 09:58 PM
97turbols's Avatar
Are you running the compressor inlet into the headlight housing area like a ram air set-up? Looks like it is going to be one killer setup!!
Old Sep 24, 2005 | 10:02 PM
ScottEK's Avatar
Default Re: EF Top Mount Update (97turbols)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97turbols &raquo;</TD></TR><TR><TD CLASS="quote">Are you running the compressor inlet into the headlight housing area like a ram air set-up? Looks like it is going to be one killer setup!! </TD></TR></TABLE>
Yeah I need to trim a little more off that housing because the b18c pushed the head up a quarter inch. At the track I'm going to run a fiberglass headlight that funnels air into the turbo, on the street there is going to be a air filter 45 degrees off the outlet.
Old Sep 24, 2005 | 10:30 PM
mrDFWmechanic's Avatar
wow thats a massive dp
Old Sep 24, 2005 | 10:32 PM
LoSt is BlaCk's Avatar
Default Re: (iROCKtheSOHC)
NICE!!!!!!!
Old Sep 25, 2005 | 07:13 AM
HybridKOOP's Avatar
Default Re: (LoSt is BlaCk)
Everything looks good... Only thing I would have positioned differently (if possible) is the wastegate placement.
Old Sep 25, 2005 | 08:24 AM
redzcstandardhatch's Avatar
something different
WOAH. i thought my ef w/turbo D had no room.
nice looking stuf.f
Old Sep 25, 2005 | 09:11 AM
B18EG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScottEK &raquo;</TD></TR><TR><TD CLASS="quote">
im a little confused with this picture, where is the slave cylinder? How are you moving the fork inside of there?
Old Sep 25, 2005 | 09:31 AM
ScottEK's Avatar
Default Re: EF Top Mount Update (B18EG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">im a little confused with this picture, where is the slave cylinder? How are you moving the fork inside of there?</TD></TR></TABLE>
Thats the Tilton hydraulic release bearing, it's totally hydrauliclly actuated instead of a mechanical fork. Couple reasons people use them is because they always let out at the same spot, it makes a twin disc easier to control, and slave cylinders can heat up from downpipes and crap out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP &raquo;</TD></TR><TR><TD CLASS="quote">
Everything looks good... Only thing I would have positioned differently (if possible) is the wastegate placement. </TD></TR></TABLE>
That actually is the only spot it can go, there is about a fingers worth of room between everything. Can't go out any further on that spot because of the 4" DP and radiator, the other side has the pipe for the back door intercooler, and in the front is the intercooler. It's a tight squeeze.
Old Sep 25, 2005 | 09:38 AM
BoOstedEM1's Avatar
Thats a nice setup. What turbo are you going with to push air into that Huge downpipe. Is there a reason you went so huge. I thought 3.5 was grand.
Old Sep 25, 2005 | 09:47 AM
ScottEK's Avatar
Default Re: EF Top Mount Update (BoOstedEM1)
Just the SC61, I would imagine that it would make a difference once you near 500hp, I'm sure companies like full-race have put a lot of thought into it and if it wasn't necessary they wouldn't be selling it. Plus as far as I know it hasn't pulled off in a crx, go big or go home.
Old Oct 6, 2005 | 10:44 PM
midwesta's Avatar
that looks awesome, where in IL are you from?
Old Oct 6, 2005 | 11:48 PM
thermal's Avatar
sick *** set-up. I like the solution for the clutch slave. I didnt know that existed. I will definitely do more research on that cuz I do plan on going with an exedy twin plate.
Old Oct 7, 2005 | 12:05 AM
OnePointFive's Avatar
overrated.
Default Re: (thermal)
lookin good scott. so that's where the CRX has been this summer hope all is well at NIU..
btw, are you and 'dad' for hire? i was wondering if you guys would be up for mocking up a top mount mani for my hatch. LS swap with a t3/t4e 60 trim turbo. PM me if you're up for it...
the rex is coming along great. i remember when it was white and without a hood
Old Oct 7, 2005 | 12:57 AM
Squirtle's Avatar
Nice setup! I am also doing my first build, so far so good. Hope everything works out for ya.
Keep us posted.
Old Oct 7, 2005 | 12:58 AM
f1 vtec's Avatar
Default Re: (OnePointFive)
that is one clean and sick setup!!!
Old Oct 7, 2005 | 05:01 AM
cinq's Avatar
Is it a MUST to have a 4in exhaust? I wonder how much gain one gets from 3in vs. 4in.
Old Oct 7, 2005 | 05:18 AM
paopao's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OnePointFive &raquo;</TD></TR><TR><TD CLASS="quote">
the rex is coming along great. i remember when it was white and without a hood </TD></TR></TABLE>
Funny you say that, cause I was just remembering back about 2 or 3 years ago when I stopped by Whip Factory and the hoodless white CRX was sitting in front. Man that was a long time ago, Leo from PasswordJDM was still combined with Dave's shop back then.
Old Oct 7, 2005 | 07:45 AM
Jays91DXhatch's Avatar
Default Re: (paopao)
Looks like you're cheating that bend on that 4" downpipe.
I know there's not much room, but your setup is DAMN clean otherwise.
Old Oct 7, 2005 | 07:57 AM
ELSpool's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScottEK &raquo;</TD></TR><TR><TD CLASS="quote">Just the SC61 </TD></TR></TABLE>
I love how the SC61 is a small turbo now..nice setup, looks killer, good luck with hitting your numbers!
Old Oct 7, 2005 | 09:00 AM
nevin's Avatar
what traction bar are you running to fit that 4in dp? are you going to produce these or is it just a one off?
a/c compatible?
