bad turbo noise
Old Sep 25, 2005 | 05:26 PM
dumpeDc2's Avatar
I'm a Jackass
Default bad turbo noise
I have a turbo that when i spin the compressor wheel It goses squeak squeak squeak like it is lacking lube is the turbo still good?
more info: it's a t3/4e garrett turbo I ran it on my stock 99Ls motor with stock exhaust for 10xxx miles. I took the turbo off because my car would blow black smoke only under boost, I figured that my head gasket or rings where going bad turns out they where. the turbo has bin sitting for 6months and when i took it of the car i just put rags in all the holes and put it in a box.
Old Sep 25, 2005 | 05:48 PM
Hybrid_Coupe's Avatar
Default Re: bad turbo noise (dumpeDc2)
yeah probably lack of oiling, or freeplay in the shaft causing the wheel to rub on the housing.
Old Sep 25, 2005 | 05:54 PM
dumpeDc2's Avatar
I'm a Jackass
Default Re: bad turbo noise (Hybrid_Coupe)
there is no play in the shaft is it still good to go?
boostedBLUfg2
Jul 5, 2011 10:00 PM
EJ8 944
Jun 16, 2008 06:47 AM
Jerm982
Oct 15, 2007 03:54 PM
AaronJ
Jan 4, 2007 02:27 PM
nigel
Apr 5, 2004 12:46 PM
