problem w/ oil return HELP PLEASE!!
Old Sep 25, 2005 | 04:10 PM
torqueless's Avatar
Default problem w/ oil return HELP PLEASE!!
im putting a t25 on my civic, and when i was reaedy to put the oil return line on the back of the block right above and a couple inches left of thr oil filter, theres a plug, and i cant get it out!!! any tips on how i can get it out?? or is there another place to tap into? such as the front of the block just left of the oil dip stick
Old Sep 25, 2005 | 04:19 PM
ogabudiah's Avatar
Default Re: problem w/ oil return HELP PLEASE!! (torqueless)
you must either use a sandwich adapter between the oil filter and the block or what you have to go into the oil pressure hole, make sure you have the right socket.
Old Sep 25, 2005 | 04:20 PM
torqueless's Avatar
Default Re: problem w/ oil return HELP PLEASE!! (ogabudiah)
can i just use the front of the block instead?
Old Sep 25, 2005 | 04:25 PM
N20civicB18's Avatar
for the return? You drill and tap your oil pan between 2 bolts as high as you can on the pan. make sure there are no kinks in the line and it can flow down smoothly
solo2fresh
Mar 2, 2011 04:09 PM
Projekt_2nr
Feb 13, 2007 12:34 AM
Jeffrey9
Feb 18, 2006 01:02 AM
jdmcx
Apr 7, 2004 06:38 AM
justinCO
Oct 28, 2002 01:07 PM
