Ignition Probs, need help ASAP!!
Old Sep 20, 2005 | 07:59 PM
BB6-213's Avatar
Default Ignition Probs, need help ASAP!!
I know this isnt FI, but i need some help quick.
I am trying to get my built h22 to start.
It has fuel, good ecu, good main relay, timed good, everything mechanically is good except it wont turn over. everything in the ignition is good.. coil, harness, all wires, cap, rotor, and the distributor reas fine, but we think that it has to be the ignitior. If the ignitor is blown, then the car will not start right? the dizzy has 30k miles on it, and i also have one that has like 50k on it, and neither one will turn it over....am I missing something? I have had numerous porple look at it, test it and everything, but nothing. so if anyone has any input to what can be wrong with the ignition please chime in.
and for reference
Motor is GOOD
Fuel is GOOD
ignition is stock (no msd)
Old Sep 20, 2005 | 08:08 PM
FredoSP's Avatar
Default Re: Ignition Probs, need help ASAP!! (BB6-213)
switch it with a working dizzy? Any CELS?
Another idea, is the timing set correctly, cam and crank?
Did you switch the order of the ignition wires on the dizzy?
Old Sep 21, 2005 | 04:09 AM
BB6-213's Avatar
Default Re: Ignition Probs, need help ASAP!! (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">switch it with a working dizzy? Any CELS?
Did you switch the order of the ignition wires on the dizzy?</TD></TR></TABLE>
Timing is CORRECT
Wires are CORRECT
there is NO spark at all
We have done every test in the Helms on the dizzy that we can and it says that its good, but it doesnt have a test for the ignitior
BSERIESDARRYL
Aug 12, 2016 08:55 AM
crappyshifting
Mar 11, 2012 05:35 PM
RoaringTurtle
Jan 30, 2002 10:50 PM
