blox turbo cams
Old Sep 25, 2005 | 05:02 PM
2k.civic.si's Avatar
Default blox turbo cams
ive searched but am unable to find any posts with someone who has experience with these cams against other cams commonly used in turbo setups....any info dyno charts etc would be great
Old Sep 25, 2005 | 07:29 PM
SEFIxCivic's Avatar
Default Re: blox turbo cams (2k.civic.si)
i made 395 whp on the blox cams on a stock motor gsr with sc61 turbo. the car ran 10.7 @ 130.
let me know if you want a set.
Old Sep 25, 2005 | 08:21 PM
Default Re: blox turbo cams (SEFIxCivic)
and do you have a comparison dyno where u only changed the cams?
Old Sep 25, 2005 | 09:58 PM
SEFIxCivic's Avatar
the car came in as is.
Old Sep 25, 2005 | 10:22 PM
sqad_7's Avatar
which blox cams were you running?
Old Sep 25, 2005 | 11:27 PM
SEFIxCivic's Avatar
Default Re: blox turbo cams (sqad_7)
these are the blox turbo cams
Old Sep 26, 2005 | 04:05 AM
kranked91dx's Avatar
I did install them into a Turbo setup I made this winter,
the car did push more hp for shure, we did feel the change pretty bad if you ask me.
however, they killed the low end, we didn't care too much since the car is running a 60-1 at 10 psi, and we didn't expect it to pull anyhow before the turbo is spooled.
Sorry no dyno graph cause we are too far from a dyno here,
they feel good though !
it was on a b16 with 9:1 comp / benson block.
hope this help
kranked.
Old Sep 26, 2005 | 08:14 AM
.nate's Avatar
cam specs?
Old Sep 26, 2005 | 11:30 AM
Default Re: (.nate)
still looking for dyno comparison of before and after with only changing the cams...seems like few use these cams
Old Sep 26, 2005 | 03:32 PM
earl's Avatar
Default Re: (2k.civic.si)
We would really need the cam specs to see if these cams were any good.
Old Sep 26, 2005 | 04:07 PM
turboEGhatch's Avatar
Default Re: blox turbo cams (kranked91dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kranked91dx &raquo;</TD></TR><TR><TD CLASS="quote">I did install them into a Turbo setup I made this winter,
hope this help
kranked.
I think you have a tuning/setup issue then, because all anyone has said is the turbo cams knock off a good bit of top end but boost up the low/mid range power.
Old Sep 27, 2005 | 02:59 PM
Default Re: blox turbo cams (turboEGhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">We would really need the cam specs to see if these cams were any good.</TD></TR></TABLE>
The specs for the turbo cams is: INT .385” / 230º EXH .350” / 225º
blox says they are high lift...far from it....
Old Sep 28, 2005 | 12:35 PM
also this was measured at .05
95turbogsr
Aug 4, 2005 11:03 PM
hunderpressure
May 11, 2005 01:10 AM
93 VTEC
Jan 24, 2003 07:11 AM
DRAGLS
Nov 24, 2001 06:35 PM
JasonNagra
Nov 3, 2001 10:08 PM
