only running 4 lbs of boost is this normal?
Old Sep 21, 2005 | 11:58 AM
mkinpwrat12g's's Avatar
Default only running 4 lbs of boost is this normal?
i have a d16y8 with a greddy 16g turbo kit. im just running a fmu and 310 cc injectors. i was watching my boost gage and i noticed when i get into it that is stops at 4 pounds. is this normal for an untuned car on no management. other than that the car seems to be running fine. it pulls very hard.
Old Sep 21, 2005 | 12:47 PM
N20civicB18's Avatar
Default Re: only running 4 lbs of boost is this normal? (blackpearlej8)
depends what your wastegate is set at
Old Sep 21, 2005 | 01:37 PM
AbitAvenger's Avatar
could be a leak, arent the greddy kits 6psi?
Old Sep 21, 2005 | 04:17 PM
SOHC_MShue's Avatar
Yes i notice most tuned car's turbos run around 20psi. If you aren't running 20psi then you must need a tune.
Old Sep 21, 2005 | 04:22 PM
ryan89crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackpearlej8 &raquo;</TD></TR><TR><TD CLASS="quote">untuned car on no management</TD></TR></TABLE>wow, have fun when you break your ringlands...i think 4psi will be the least of your worries
Old Sep 21, 2005 | 04:37 PM
SOHC_MShue's Avatar
Default Re: only running 4 lbs of boost is this normal? (ryan89crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx &raquo;</TD></TR><TR><TD CLASS="quote">wow, have fun when you break your ringlands...i think 4psi will be the least of your worries</TD></TR></TABLE>
he has a fmu...not the best, but i doubt it will break on 4lbs with a fmu.
406EVO
Engine Management and Tuning
Oct 18, 2011 10:39 AM
bboysake
Jun 28, 2006 09:54 AM
SoHc84
May 27, 2005 08:25 AM
Sam1am26
Nov 26, 2004 06:51 PM
boostincoupe
Sep 26, 2004 05:56 PM
