Oil Cooler's
Old Sep 25, 2005 | 06:54 PM
LSEGHATCH's Avatar
Default Oil Cooler's
How many of you are running oil cooling setups on your boosted cars? I never see/read in magazines of honda's running oil cooling setups, so I figured I'd ask.
Old Sep 25, 2005 | 07:27 PM
drift2004's Avatar
Default Re: Oil Cooler's (LSEGHATCH)
i am my friend!\
Old Sep 25, 2005 | 07:34 PM
Quad-Damage's Avatar
Default Re: Oil Cooler's (drift2004)
Im runing a B&M Greddy Custom oil cooler setup
LOVING IT
Old Sep 25, 2005 | 07:36 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Oil Cooler's (Quad-Damage)
i wanna run one.. not running one yet tho.
Old Sep 25, 2005 | 07:39 PM
drift2004's Avatar
i put it on because i saw in sportscompact magazine that it increased some horsepower they did testing on a 240sx and your car should run better
Old Sep 25, 2005 | 08:59 PM
KeyserSoze's Avatar
I am running one as well. Got a nice priced cooler off of ebay, sandwich adapter and ss braided lines from summit. I have a 94' gsr so it has the stock oil cooler, but figured that this couldn't hurt.
Old Sep 26, 2005 | 07:06 PM
LSEGHATCH's Avatar
How much power are you guys pushing out? I was thinking that if you have a larger front mount/Oil Cooler/Radiator that the amount of air flow through the last two would be restrictive.
Old Sep 26, 2005 | 07:39 PM
mike1114's Avatar
Here is my setup. Got the cooler off ebay for $89. Oil filter relocator for $59, lines for like $50 total. I do not run a thermostat on the cooler but I live in Florida, its always hot as hell here. In the winter, I'll just block it off.
Car is daily driven. Takes a while to warm up. I usually start the car 5 min before I go anywhere for the first time in the morning.
Cooler is 12 Long X 2 Thick X 4-5 High
Motor is fully built ls/vtec turbo
Old Sep 27, 2005 | 05:54 PM
mike1114's Avatar
Default Re: Oil Cooler's (mike1114)
bump, wanna hear more from others.......
Old Sep 28, 2005 | 08:17 AM
White Smoke's Avatar
i my honda
Global Mod
I run one
No pics tho
I DO run a thermostat.
Here is a nice little write up to answer all your questions.
Old Sep 28, 2005 | 09:58 AM
stockredej1's Avatar
Default Re: Oil Cooler's (White Smoke)
i plan to get one soon. do i need a thermostat? it is a daily driver and we get alot of snow here.
Old Sep 28, 2005 | 12:00 PM
i my honda
Global Mod
Default Re: Oil Cooler's (stockredej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockredej1 &raquo;</TD></TR><TR><TD CLASS="quote">i plan to get one soon. do i need a thermostat? it is a daily driver and we get alot of snow here.</TD></TR></TABLE>
YOU REALLY NEED ONE!
Old Sep 28, 2005 | 10:27 PM
b18ccivics's Avatar
mike1114 what adapter is that and where can i get one
Old Sep 28, 2005 | 11:03 PM
Dee's Avatar
Dee
Default Re: (b18ccivics)
On the old car
The new beater
On the new car the OC has aluminium shields that direct air in from the top and out through the opening in the bumpa! The shield also keeps the heated air off of the IC piping. The mounts for the OC have changed since I took this pic.
This is the APP SFIDA kit with a temp controlled sandwich.
Modified by Dee at 12:56 PM 9/29/2005
Old Sep 29, 2005 | 04:44 AM
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18ccivics &raquo;</TD></TR><TR><TD CLASS="quote">mike1114 what adapter is that and where can i get one</TD></TR></TABLE>
Perma-Cool Spin on Adapter # 116 20 mm X 1.5
Didn't bother to check out the site I posted huh
Buy here
Old Sep 29, 2005 | 04:54 AM
mike1114's Avatar
Default Re: (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">
skuded
Sep 12, 2010 05:28 AM
RedneckRicer
May 16, 2008 10:48 AM
rkrone
Jun 29, 2006 09:52 PM
AznPrideYo
May 14, 2004 09:46 AM
