Having problems spooling quicker
Old Sep 22, 2005 | 11:05 AM
extreme95gsr's Avatar
Default Having problems spooling quicker
The setup is an sc61 with an inline pro mani on a gsr bottom end (84mm sleeves) with 9.2:1 static cr. I'm using an avc-r along with a tial 38mm. Here's the problem: On pump gas I'm tuning for 1.2 bar (about 17.5psi), however I dont reach full boost until redline. You can practically draw a linear graph of rpm versus psi because as the rpms increase, so does boost. Obviously I want to hit full boost a lot sooner than that. Right now the duty on my avc-r is set at 80% for 1500-4500rpm and 70% from 4500-redline. I could raise the duty to 90% but do you really think that will make enough difference? I'm thinking something else might be the problem. Any ideas?
061000rr
Jun 14, 2011 04:37 AM
UJLSMoFo
Nov 15, 2009 07:02 PM
rudebwoy
Mar 17, 2007 12:53 PM
dohcguy
Jun 4, 2005 05:05 PM
gsr sol
Mar 2, 2003 02:33 PM
