setups...
Old Sep 24, 2005 | 10:17 AM
B18Sleeper's Avatar
Default setups...
Just wondering what most people in here are running for theri turbo setup, and engine mods. And what numbers do some of you all pull? Thanks
Old Sep 24, 2005 | 10:31 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: setups... (RedlineKustomz)
Block
b18a1 block
darton mid sleeves
84.5mm cp pistons, 9:1 cr
manley rods
acl bearings
knife-edged, micropolished, chamfered and fluted ls crank.. also had the oil gallies drilled, honed and plugged.
fluidampr
golden eagle electric waterpump kit with idler blockoff
ITR Oil Pump
Golden eagle ls/vtec conversion kit
Head.
GSR Head
Stage 5 porting and polishing by RPMnyc
Ferrea Valve Guides
Supertech 1mm oversize black nitride coated valves (being replaced)
crower springs and retainers (being replaced)
ITR Cams with AEM Cam Gears (gone)
Ferrea VTEC Killer rocker arms (coming soon)
Custom intake manifold by RMPnyc
75mm Mustang throttle body
Golden Eagle Head Studs
Turbo
Fab-works manifold, downpipe and dumptube
Tial 44mm wastegate
Turbonetics Raptor BOV
PWR FMIC
Custom built garrett gt series turbo
Fuel
complete aeromotive fuel system, pump regulator, etc.
10-an feed line and 6-an return
custom pump pickup system (intank uses stock pickup)
ERL Fuel Rail
Precision 1000cc Injectors
Drivetrain
OS Giken twin disk clutch
Gator Stage 3 Axles
OBX LSD
Electronics
AEM EMS
AEM UEGO Wideband (gauge type)
AEM 3.5bar map sensor
GM Boost control solenoid
GM IAT sensor
BRAKE SYSTEM
Wilwood triple reverse mount pedal assembly
3 Wilwood 1" Aluminum master clinders
custom best hard lines..
Wilwood 12.2" Front drilled/slotted rotors
4 piston dynalite calipers
2 wilwood proportioning valves
11" Rear rotors
i think that about covers it... the reason most of the valve train is being replaced is that i should be picking up ferrea as a sponsor in a week or two and i will be getting a full valvetrain from them... 1mm os valves, custom valve springs, ti retainers, the vtec killer system along with custom built cams and cam gears.
all in all i should be able to acheive 500whp on pump gas at 18psi with this setup, maybe a little more with the ferrea parts
Modified by wantboost at 12:24 AM 11/21/2005
Old Sep 24, 2005 | 10:40 AM
93supercoupe's Avatar
Default Re: setups... (wantboost)
with that setup, 500 should very modest, pump gas or not.
Old Sep 24, 2005 | 11:02 AM
B18Sleeper's Avatar
Default Re: setups... (93supercoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">
acl bearings
fluidampr
GM IAT sensor
Ok these parts above where are some goods site to find those? Cuase I Have looked for half of that for a long time and still aint ever found them online.
JDM.Jay
Jan 24, 2015 12:11 PM
theycallmekevin
Feb 1, 2012 06:55 PM
slick1851
May 29, 2010 10:48 AM
EncoreRSX
Apr 13, 2010 09:37 PM
jksmith
Apr 17, 2008 03:26 AM
