blow off valve location???
Re: (gssr)
there has been a lot of debate on this subject, however no matter what it needs to be at least 12" from the throttle body. It is debatable but a lot of people(all the people who matter) would say on the hot side of the intercooler is the best place for the bov, meaning ON the intercooler.
I have mine on the hot side. I figured that if I have to blow off some air, it would have to be hot air instead of cold air.
But again, thats just me. I don't know if it helps or not.
Re: (extrmeboost)
Ive seen 800+hp supras with blow off right out the ic cold side and doing just fine. Yet thats not where im going to put mine its just the fact people put where there opinions are at.
Re: (12SEC CIV)
I seriously doubt it matters. There are just as many people making great numbers and having good reliablity with it on the cold side as there are with the hot side. As far as someone opting to blow off hot air instead, it really wont matter since its all passing through the intercooler anyway.
Re: blow off valve location??? (12SEC CIV)
I think it is probably more efficient near the turbo on the hot side, but you can put it on the cold side and be just fine. Mine is going on the cold side, but if I wasn’t running a/c I would run a backdoor w/ it on the hot side.
Re: blow off valve location??? (97turbols)
If youre running enough boost you could have one on each side of the IC. Ive seen some high boost Supras with it. I have mine on the cold side, about 12" from the TB.
Location: The Village Hidden in the Leaves: Seattle, WA
Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">hmm how about 2 bovs? one on each side </TD></TR></TABLE>
that's what it says on the post above yours!
