OVERHEATING ..... Need ideas why??
Old Sep 23, 2005 | 08:31 AM
Da K00l Aid Mayun's Avatar
Default OVERHEATING ..... Need ideas why??
Ok, so my car finally came out of the shop:
84mm sleeved B18C1
Full-Race Manifold
T4/T67
Koyo Radiator
Hondata
Now for some reason the car is overheating. No smoke from the exhaust, no abnormal driving behaviors. The car will drive for about 15-20 minutes then all of a sudden just start slowly moving up in temperature until it gets to hot. We have pulled the thermostat completely out of the car and the overheating still occurs. Any ideas as to why my car is randomly overheating? Engine only has about 45 miles on it since being sleeved and rebuilt.
Old Sep 23, 2005 | 09:51 AM
Default Re: OVERHEATING ..... Need ideas why?? (Da K00l Aid Mayun)
ttt
Old Sep 23, 2005 | 09:55 AM
FyReo3's Avatar
What kind and size of intercooler?
Old Sep 23, 2005 | 10:01 AM
Rufus523's Avatar
User Mike1114 had a list with the usual suspects on here somewhere. Since they just built the engine, I would try things in this order:
1. Put a honda thermostat back in (and leave it in)
2. Let the car run with the rad cap off for a while (15 minutes) after you fill it up with around 60-70% water and the rest coolant and look for the bubbles
3. Make sure your fan is coming on
4. Get an oil cooler (if you don't have one already)
Mine (and a few others) did the same thing, but the aluminum radiator all but solved my problem. I just drove my car 7 hours to NC and it only went a little over half. Granted my setup is more mild then yours.....
Old Sep 23, 2005 | 10:05 AM
Default Re: OVERHEATING ..... Need ideas why?? (FyReo3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FyReo3 &raquo;</TD></TR><TR><TD CLASS="quote">What kind and size of intercooler?</TD></TR></TABLE>
Precision 750hp Intercooler
Old Sep 23, 2005 | 10:35 AM
yee SERIOUS's Avatar
^^^ ic blocking air to the radiator? are you using a stock fan? like mentioned above, make sure it's coming on.
Old Sep 23, 2005 | 10:40 AM
Default Re: (undercoverdc2)
yeah, fan comes on, and its a flexalite fan on a Koyo radiator
Old Sep 23, 2005 | 10:56 AM
Default Re: (Da K00l Aid Mayun)
I was hoping for more response than this, lol
Old Sep 23, 2005 | 11:10 AM
Rufus523's Avatar
Well if you already checked the things above (mainly the OEM Honda thermostat), then it is something else:
1. IC blocking air to rad as mentioned, not much you can do but make a vent etc.
2. Reduce temps another way, oil cooler, coating, wrapping, whatever.
I have to be honest, there are some big hp cars running around with stock radiators. I don't know how.
Along the same lines, there are a lot of people on here that have been having this same problem. No definitive answer, just wait until winter to drive I guess. Good luck.
Old Sep 23, 2005 | 11:58 AM
^^^ but how many of those big hp guys are daily driving their beasts? lol
Old Sep 23, 2005 | 12:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by undercoverdc2 &raquo;</TD></TR><TR><TD CLASS="quote">^^^ but how many of those big hp guys are daily driving their beasts? lol</TD></TR></TABLE>
like me, lol
Old Sep 23, 2005 | 01:02 PM
any other ideas?
Old Sep 23, 2005 | 01:39 PM
FyReo3's Avatar
Intercooler is your problem. I am having the same issue, and I have the same IC. It does not allow air to the radiator. I also compound my problem by having my DP right by the rad. I have tried everything except cutting the bumper, for which I do not want to do. I added a second fan, it seemed to help but I still have to turn the heater on when at a stop. Good luck.
Old Sep 23, 2005 | 01:40 PM
Default Re: (FyReo3)
thanks guys, we figured it out, runs perfect now
Old Sep 23, 2005 | 02:00 PM
cmyrex's Avatar
you can try pancaking a cupple of radiator fans just to see if that helps the ones for a/c are real small and you can modify them to work in about any small space. But this might be avoiding the problem at hand
Old Sep 23, 2005 | 03:01 PM
Default Re: (cmyrex)
we fixed it, thanks though
Old Sep 23, 2005 | 04:03 PM
Rufus523's Avatar
Could you please share the solution?
Old Sep 23, 2005 | 04:13 PM
Default Re: (Rufus523)
lol, the fan was wired backwards, it was blowing away from the radiator instead of towards it.
Old Sep 23, 2005 | 04:21 PM
AlphaQup's Avatar
where did you mount the fan? puller - behind the radiator, or pusher - in front of the radiator? and are you using the half sized koyo radiator.
Old Sep 23, 2005 | 05:08 PM
Default Re: (AlphaQup)
full size, and its a puller. It runs perfectly now, been driving it all night and hasn't gone past halfway on the temp gauge
Old Sep 23, 2005 | 05:56 PM
Tad's Avatar
Tad
Dude u tried burping/bleeding the cooling system?
maybe theres just an airbubble in there..
hows the levels in the overflow tank?
Old Sep 23, 2005 | 06:34 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Da K00l Aid Mayun &raquo;</TD></TR><TR><TD CLASS="quote">lol, the fan was wired backwards, it was blowing away from the radiator instead of towards it.</TD></TR></TABLE>
doh!
Old Sep 23, 2005 | 06:41 PM
Tad's Avatar
Tad
oh, haha
Oscar Ponce
Feb 26, 2012 11:15 PM
bikewithnoname
15
Apr 2, 2009 11:34 AM
twenty
Jul 21, 2005 04:32 PM
bitr364
Jul 22, 2003 02:03 PM
Gabe_
12
Jun 13, 2003 02:47 AM
