Need AFC hack settings QUICK.... VAFC just reset
Old Sep 22, 2005 | 02:47 PM
Cee_mon's Avatar
Default Need AFC hack settings QUICK.... VAFC just reset
Hey guys...The vafc was tuned and running great for 2 years, then today i got into the car and the screen just went dim, so you couldnt read it. I remember somewhat what the settings are suppose to be. I do have a wideband to tune it with. But there used to be a page on dropzone that had ALL the settings. That page is down now and i cant seem to find any settings. I searched the AFC hack explained thread and most of the links are to the dropzone page.
I need to know things like rpm settings for example ...
NE1 - 1000
NE2 - 1500
NE3 - 2000
So if anyone knows a link with the settings please post it up. Or if you know them can you please PM me or post them up.
I really need the help as i gotta get to work tomorrow.
Old Sep 22, 2005 | 06:30 PM
Cee_mon's Avatar
Default Re: Need AFC hack settings QUICK.... VAFC just reset (Cee_mon)
Bump...I got the car running decent now. Only thing i notice and iam concerned about is it takes about 30-40% to start to make boost while (on a greddy kit on d16z6) while before i would start around 26-30%. I have checked the sensor check on the vafc for TPS and its coming in at .45volts which i think it is suppose to be.
Old Dec 20, 2005 | 12:47 AM
pramonn's Avatar
Check this out for the manual, it will help you on setting dim-bright screen.
http://www.apexi-usa.com/support_installation.asp
But for the set up.....I use to wonder why not many people hand over his/her setting to the others.
After I finished my own setup I think I quite under stand, cos diff car is diff setting.
Someone setting might or might not work well for others.
But usally VAFC hack people start with something around -40 to -35 across, then street tune or dyno tune for better/best results.
Old Dec 20, 2005 | 02:27 AM
thermal's Avatar
recheck your setting:
http://www.geocities.com/therm....html
I've never had a problem with mine. It felt good.
Old Dec 20, 2005 | 05:34 AM
pramonn's Avatar
Default Re: (thermal)
Yes thermal setting is working for me...... .......
Just a little bit fine tune to fit for myself
LVT
-37 @ 1000
-36 @ 2000-4000
-35 @ 5000 to the end
and -35 across for HVT
set the same for wide and narrow
TH point is 72-73
VTEC engagement as per MFG.(5500)
Thanks for thermal writeup
Old Dec 22, 2005 | 07:09 AM
thermal's Avatar
Default Re: (pramonn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pramonn &raquo;</TD></TR><TR><TD CLASS="quote">Yes thermal setting is working for me...... .......
LVT
-37 @ 1000
-36 @ 2000-4000
TH point is 72-73
Thanks for thermal writeup </TD></TR></TABLE>
I'm glad to hear that man
Vtecme92
Jun 4, 2006 12:44 PM
LoseRPunKx182
Jul 13, 2005 03:34 PM
autoEXturbo
Jul 18, 2002 05:03 AM
