Anyone in So CaL that can tune Emanage??? Also question on timing control
hey guys, I wanted to know if there is anyone in So CaL you have used that can tune an Emanage and tune it well. This will be on a dyno of course and i have my own wideband. setup is 99 civic DX with the Greddy 19t kit. I was also wondering about the ignition control harness that Greddy sells as an add on, can I just use the harness with the stock crank sensor? or do i need to do anything further? also does the harness plug and play or do I have to wire it directly to the crank sensor?
Last question, will I benefit enough from the timing control to buy the harness or will stock timing be safe enough at 10psi?
Thanks for any help!!! beers for everyone
Re: Anyone in So CaL that can tune Emanage??? Also question on timing control (ToasterOven)
where in socal? i'm pretty sure any shop can tune your emanage. and if you want a full tune then get the injector and ignition harness also.
Re: Anyone in So CaL that can tune Emanage??? Also question on timing control (jayswift)
found a shop to tune, Church's. Can't the emanage tune by adjusting the pulsewidth of the 310cc's that come in the kit without the injector harness?
seanjohn81
12-06-2002 06:29 AM
