Missing link necessary?
Old Sep 22, 2005 | 06:51 PM
CJJones87's Avatar
Default Missing link necessary?
hey guys. Ive got my whole revhard setup and was going have it installed tomrrow. However I don't have a missing link... I was wondering if this would pose a problem. I will only be running 7 psi, but I wanted to check if a missing link HAS to be installed. I was going to order one this weekend and put it in next week so I would only be running without one for about 4 days. I just wanted to get the turbo on this weekend because i can't do it in the week between school and work. Any help is appreciated.
Old Sep 22, 2005 | 07:12 PM
spoolinup's Avatar
Default Re: Missing link necessary? (CJJones87)
u will have to use a missing link if u arent running any kind of fuel management.
Old Sep 22, 2005 | 07:15 PM
CJJones87's Avatar
Default Re: Missing link necessary? (spoolinup)
Ive got a 12:1 FMU. Is that enough?
Old Sep 22, 2005 | 08:37 PM
spoolinup's Avatar
No thats not what i meant.i meant crome,uberdata,hondata,aem etc. that type of fuel management.Those programs are meant to read boost ,yer stock ecu isnt.Thats why u use a missing link to trick yer stock ecu so it doesnt read boost.If yer stock ecu reads boost it will go into lymph mode and through a map sensor code.So the to answer yer question,yes get a missing link u need it.
Old Sep 22, 2005 | 10:06 PM
hondaxsimike's Avatar
the missing link keeps the MAP sensor from seeing boost. this is why you must have it if you arent running engine management.
Old Sep 23, 2005 | 10:56 AM
N_A_is_best's Avatar
Default Re: Missing link necessary? (hondaxsimike)
just go to a local petsmart or wherever sells oneway checkvalves... for every one checkvalve you can prevent up to 2 pounds of boost from getting to the map sensor... my friend has 4 of these inline to his map sensor and never has map senser problems
goodluck
Old Sep 23, 2005 | 12:04 PM
yee SERIOUS's Avatar
you'll need a missing link or run check valves at the least
Old Sep 23, 2005 | 12:41 PM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinup &raquo;</TD></TR><TR><TD CLASS="quote">lymph mode </TD></TR></TABLE>
LOL!
Old Sep 23, 2005 | 08:26 PM
CJJones87's Avatar
Default Re: Missing link necessary? (notoriousB)
Alright. Would I be able to drive the car for less than a week until the missing link gets in the mail or would I be risking blowing my motor or something?
Old Sep 23, 2005 | 08:36 PM
Jon at Titan's Avatar
u need the missing link if not the map will see boost and go into limp mode, Check Valves or Missing link, Dont drive with out it
Old Sep 23, 2005 | 09:23 PM
Muckman's Avatar
Moderator in Chief
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinup &raquo;</TD></TR><TR><TD CLASS="quote">If yer stock ecu reads boost it will go into lymph mode</TD></TR></TABLE>
Classic!!
Old Sep 24, 2005 | 02:45 AM
KeyserSoze's Avatar
Thanks for the chuckle.
Old Sep 24, 2005 | 03:31 AM
DARKSIDE_TEG's Avatar
i ran my turbo on my GSR without it for a couple of weeks i've even had street races... i heard not a good idea, YEAH when you start to boost in the 4-5 lbs the CEL will come on ...try not to boost to high because your ECU will throw a CEL. drive normal and it'll be fine, after the missing link i had no problem... except for my leaning out, which is a different problem ....
Old Sep 24, 2005 | 08:31 AM
anguish's Avatar
w/o it you will get CEL after a few pounds of boost.. i wouldnt drive it unless you really have to. it should be fine for a few days just go easy on it. ebay
Old Sep 24, 2005 | 07:13 PM
CJJones87's Avatar
Default Re: Missing link necessary? (anguish)
OK. Well from what I'm hearing, it'll be OK for a lil while (I'll only be driving without it for about 4-5 days), so I'll just go easy on it until I get it in. Thanks for all the help.
Old Sep 25, 2005 | 05:59 AM
Laserjock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolinup &raquo;</TD></TR><TR><TD CLASS="quote">lymph mode</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">
LOL!</TD></TR></TABLE>
man, you guys don't know hao to spiel! it's lymph node ha ha
Old Sep 25, 2005 | 06:25 AM
Muckman's Avatar
Moderator in Chief
Default Re: Missing link necessary? (Laserjock)
Spell
Old Sep 25, 2005 | 09:14 AM
nota-eg's Avatar
Default Re: Missing link necessary? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Spell </TD></TR></TABLE>
No, spiel. Like "Damn it! I spieled my beer!"
You'll be fine without your missing link as long as you don't try to push it hard. Stay out of boost and you'll be fine.
Old Sep 25, 2005 | 10:11 AM
Laserjock's Avatar
Default Re: Missing link necessary? (nota-eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg &raquo;</TD></TR><TR><TD CLASS="quote">
You'll be fine without your missing link as long as you don't try to push it hard. Stay out of boost and you'll be fine.</TD></TR></TABLE>
i don't know what is up with all the emotikoontz butt you all jus kneed to ansear da doods kwestyon abowt de messing lynch!
Old Sep 25, 2005 | 10:28 AM
nota-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laserjock &raquo;</TD></TR><TR><TD CLASS="quote">i don't know what is up with all the emotikoontz butt you all jus kneed to ansear da doods kwestyon abowt de messing lynch!</TD></TR></TABLE>
Aye deed.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nota-eg &raquo;</TD></TR><TR><TD CLASS="quote">No, spiel. Like "Damn it! I spieled my beer!"
standbackimapro
Jun 8, 2008 11:10 PM
nicktagz
Sep 24, 2006 05:38 PM
D15Bbigred
Feb 21, 2006 07:57 AM
Treblarefils
Feb 23, 2005 11:26 AM
Turbohatch
Jul 2, 2001 10:35 PM
