how much nitrous should I use? on a turbo sohc
I have a d16z6 with full ferrea valvetrain, pnp head and port matched intake mani.
cp 9to1 pistons, eagle rods, block gaurd
running 12-14 psi on stock eclipse turbo.
how much can I spray and be relatively safe?
Re: how much nitrous should I use? on a turbo sohc (alexsracing)
You could always tune for more boost....that setup should be safe at 20psi - but swap that eclipse turbo for a 16g or 20g.
liam
liam
You can spray whatever you want with the proper system and tune. What kind of goals do you have for the car? Anything 100HP and down would be a pice of cake. If you are running some kind of MBC you may notice some healthy boost creep, but then again.... is that a bad thing lol? I've seen those motors over 400fwhp with a little spray on top of boost, they just eat it up.
A 75 shot isn't even impressive for a purge kit. It honestly is just a little tickle of nitrous, your engine will handle it just fine and beg for more (assuming you run a good tune).
Re: (Phase Change Racing)
start low 35 shot then work your way up tunning as need be. As far as how much it will take that is up to you and how well you tune it.
I sprayed a 75 last night at the track to test it buy only in 3rd gear. didn't feel like what I was expecting.
more like another spool
Re: (alexsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoJo1190 »</TD></TR><TR><TD CLASS="quote">whatever it is...
get 2 bottles</TD></TR></TABLE>
ha ha ha ha...
wait, ive got a bottle going on my R soon...
ha ha ha ha...
EJ8CIVIC
44
08-06-2006 03:08 PM
